Dyno will be located NOR in Balga.
Its not really about thrashing your engine if more making sure its healthy. PLug the wideband unit in check afr's
Also to be used for tunning your car as will will have most tuning software/hardware there.
Looking at buying the dyno soon and just wanting to see how much use it will get to help pay the payments on it
https://www.sau.com.au/forums/topic/189712-dyno-use/#findComment-3418625
Yes me and my business partner are buying a dyno for our workshop.
This is only a part time thing for now but hopefully will turn out to be a full time job.
We have been looking around at hiring dyno's for tuning and found them really expensive.
We figured 2 runs a week will pay off buying our own.
So if we get it i want to offer it to people at a much lower price as i know how hard it is to get time with one.
https://www.sau.com.au/forums/topic/189712-dyno-use/#findComment-3419044
I'd pay money to use it for an hour or so once I get my engine in, then again when its run in and boosted up. Would be great to be able to use a dyno to DIY tune rather than using the road.
Would also be cool if you did a cheap R32 reflash & tune. If you want any technical info on it let me know.
https://www.sau.com.au/forums/topic/189712-dyno-use/#findComment-3420433
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
