hey i just bought replica rs bov, for my '96 r33 skyline, and i put it in last nit at my mates, we drilled new holes onto the stock cross over piping, exactly wer the stock bov goes, and mounted it there with know problems and no leaks!
took for a few runs, adjust the hardness & softness of the new bov.. got it about rit..
so i drove home fine!
the only thing that i noticed was that wen down gear and clutch was all the way in, and i didnt release it, the revs would drop from 1500rpms to bout 100rpms, but didnt stall, and den went back up to normal idle revs, lik 500-600rpms...
PROBLEM:
so i got in my car dis morin, drove to my other mates place, who lives bout 2ks away, and was all fine!
then wen i left i got to bout 2000rpm, and it felt like it was bunny hopping! or sumthing??
MY MODS:
i just got a new (afc)apexi neo fitted and tuned,(at 500rpm/1000rpm my correction is -8%. etc..)
front mount intecooler, splitfire coilpacks, re-gapped .6mm spark-plugs,
turbo-tech boost controller/bleed valve, HKS 3" cat-back exhaust.
IDEAS:
new bov needs to tighten(all the way to hard setting)??
afc correction to lean?needs to be adjusted..???
afm??how often do these r33 afm fail, go fautly??
on the back of the bov's there a vac. line that connects to the intake manifold,
should this pipe be a certain min/max diameter, length? if so how long and thick?
any ideas would help...
https://www.sau.com.au/forums/topic/189771-r33-new-bov-driving-problems/
atmo bov's do that...leaks boost as u start to make it so drives like a b!tch....and revs go nuts wen u pull up at lights. look at ur bosot gauge and tacho and u know wat we mean...climbs n drops..climbs n drops...its tryna compensate for the leak
I'm putting my money on leak, I have had intercooler piping come off many a times, and anytime you try and put any sort of power down, it feels like it's bunny hopping...
Check your piping and schtuff :thumbsup:
a leak u reckon? best way to find a leak then????
wat bot:
would that make diff?
if it is doing it when you accelerate then you have a problem that. whether the bov is atmo or not shouldn't make a difference during acceleration, unless the bov isn't closing properly.
now the bunny hoping you are talking about, is it bad like a leaner driver, or is it more of a missifre? the fact that you are running 0.6mm gap plugs with splitfire coils worries me. do you have to run the gap that small to have it not missfire? if you do then you have a serious problem with the splitfires.
yeah, it happen wen i accelerate, and was only in first, and yeah, hit just over 2000rpm and yeah..started hoping!
i think i put it in second and it did it aswell round the same rpm..
now wat u mean by..
"bad like a leaner driver"
well my plugs + coilpacks r fine
and its similar to misfire..but feel liks no fuel..
fuel pump? afm?
i have no clue ay..
sorry, cant remember, it was early dis morin wen it happin..and i didnt have time to have a good look..
i tried turning down the valve to make it harder..but no good..
mit turn it all the way down..
but as for driving im pretty sure i was and had my foot down lik a normal driver, dont think my foot-slip or i was back-off or anythin..
i was just driving...lol
Yeah, wen i put my foot done it didnt pass 2 to 2.5k as i mention earlier..
it struggled for some reason..
but i did find my problem..
something 2 do with my apexi afc/neo!!!!!!!!!!!!!!!!!!
so i reset it and it drove fine..
well....it uses more fuel now..lol
so i adjusted the air-map myself just on low throttle. and seems to be if not better than before!
the first place i got my tune done, and the at the same time got my apexi NEO fitted..
they didnt change/adjust the DEC AIR or the THROTTLE %..
so i really just changed those..
and my low-throttle from 1,2,,4,5,6,7 and i curved the map..
at 3000rpm i left it 0%(so no changes) coz that wen boost kicks in..well round der..lol
and i dont want to lean it out der.
so i gota get a re-tune and coz it using a bit of fuel..
but has anyone got AIR MAP details?
im gona start-up another topic to c wat people setting ther afc air map set at...
Edited by bumble_bee
so.. i took ma car to speedworks in perth, they re-tuned ma afc..
it was oxygen sensor that was playin up!!
so they dis-connected it..and did the tune wit out it
doesnt stall at all anymore! and drives beta!!!
just still uses a bit of fuel..
thank god i work for nissan, and ive already got and put in the new o2 sensor..
but my 33 still chug's fuel..
speedwork had a hell different air map settings than ovaboost..
so i wondering, whould tuning an afc with the o2 sensor connected they re-connecting a new, make any difference?
or would u need a re-tune..???
Sounds like your mixtures were out and the cars gone into limp mode to try make it through the rest of the day. Should of got it tuned properly ages ago...
Mate your cars driving crap because of the style of BOV you've got. Excess air is vented to the atmosphere and not back into the engine (i.e. plumbback). The ECU has measured the amount of air coming into the system through the AFM and is ready to control the a/f ratios but as the excess air is simply vented out of the closed loop the ECU has simply lost it and mixtures are all over the place and the ECU is trying to compensate all over the place
na, my car is fine now since i got the o2 sensor fitted and lowered some of the % of the high throttle air map settings..
all good..i havent had that bunny-hop/learner problem since..
and i get around 400k's outa my 50L tank now,
so yeah..
and i still got the atmo bov connected..and my idle is fine..
i cleaned out the acc and i believe that made a hell of a difference ay...
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
