  • Replies 70
i dont really think he is a cop ... just by chance two cop cars pulled up beside him at maccas this morning. Hope he didnt get busted for anything...
(ill see if i can fix the post name)
edit: cant see how to fix the post name to MRR34 .. can a moderator change it?
Edited by Grrr
Just because I've given you a speeding ticket doesnt mean you have to be a hater. I'm just doing my job mate, that is keeping young people alive.
I think that bottom lip on ur car is illegal... lol jkz.
Edited by silverbulletR33
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
