  • Replies 70
This makes me sick to my stomach! Is nothing sacred anymore? Man i'm so confused , angry and well i feel violated!
RLOL, cops driving Skylines, being members of SAU and invading this forum. What are they spying now, prepping theriot squad to bust some ass up at the next cruz? I don't know, suppose we've got the small minority of idiots like the stones corner robbers to thank for all this.
I'm going to self medicate now, should've taken the blue pill.
i seen his badges and umm special undercover stuff ;) ... didnt u notice a silver 4 door trailing behind watching over every cruise we organise ? mikey u did well hiding your secret weapon !
if u guys r really cops (it makes sense, how else would they catch all those skyline driving 200kph+ bandits? with a R34!!), does that mean u can help out the forum by clarifyin defect laws so we can make sure our cars r roadworthy and stay that way?? to all the police officers out there, keep up the good work.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
