SAU QLD GAME.. take a stab. u may win a free drink
99 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 159
you said it has a factory compressor..and it sounds like a supercharger so it has to be a supercharged 4AGZE doesnt it?
either that or twin charged
what other engines on the list are factory super charged?
I haven't watched it but with the clues...
9000rpm rules out:
SR20
CA18
RB20
RB25
RB26
LS1
1JZ
2JZ
7MGTE
3SGTE
VG/VQ
VH45DE
4G63
That leaves
L28
4AGE/4AGZE
You already said no to 4age/ze
I guess L28
You also said "a" factory charger.
So I'm guessing L28 using a supercharger from a Toy Yoda
9000rpm rules out:
SR20
CA18
RB20
RB25
RB26
LS1
1JZ
2JZ
7MGTE
3SGTE
VG/VQ
VH45DE
4G63
That leaves
L28
4AGE/4AGZE
I guess L28
doesnt rule out any rb's
specially not a forged one.
rules out most of the others though.
9000rpm rules any motor if the idiot wants it to survive for any real length of time, especially if he is actually racing it on/off at track/drags. Doesnt matter how 'built' it is. A small capacity 4 would do it easier and have half a chance of surviving, something with a big bore and short stroke.
there was no mention of a forged engine.
therefore, rules out all RB's except maybe an RB20 for a duration of 3 seconds.
The only built engine mentioned was the 4G63 which he has said is not it.
L28's like to rev (but it doesn't sound like a 6)
3s and CA18 also like to rev.
that clip doesn't sound like a 6.
it's defo a 4.
SR20 doesn't sound like that at all.
4agze ruled out.
to make it all easy, I'm going to stick with one final guess.
CA18DEZ (supercharger from a 4agze or a 1g-gze)
Tell me I'm right you southside loving bogan!!
:P
This is my mates
Just a lil game i wanna make up. this is my mates S13 take a guess of the engine and charger if it is charged set up.
be the first to get both correct and tell me and ill shout u a drink at the next Tuesday night dinner. :P
Have fun.. no cheating now. discuss it if u wish but PM me with ur correct answer. first correct answer wins.. 1 entry per person.
cheers
mark.
S13 vid was taken on private land oh and it is reving to 9000rpm and has been built:)
Mods please leave this. its just a lil competition for the QLD members no harm and is car related :(...
see bold
it's defo a 4.
4agze ruled out.
it sounds like a 6 to me, sounded like my engine before i put an exhaust on it...and the fact that you can hear it die off up the rev range leads me to think it is a stock compressor. i have seen people run 20 to nine on the track, of course it wont last f**k all time if you keep revin it there....but it still does it atm.
Sounds like an Electrolux...
bahahahaha
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
