SAU QLD GAME.. take a stab. u may win a free drink
99 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 159
you said it has a factory compressor..and it sounds like a supercharger so it has to be a supercharged 4AGZE doesnt it?
either that or twin charged
what other engines on the list are factory super charged?
I haven't watched it but with the clues...
9000rpm rules out:
SR20
CA18
RB20
RB25
RB26
LS1
1JZ
2JZ
7MGTE
3SGTE
VG/VQ
VH45DE
4G63
That leaves
L28
4AGE/4AGZE
You already said no to 4age/ze
I guess L28
You also said "a" factory charger.
So I'm guessing L28 using a supercharger from a Toy Yoda
9000rpm rules out:
SR20
CA18
RB20
RB25
RB26
LS1
1JZ
2JZ
7MGTE
3SGTE
VG/VQ
VH45DE
4G63
That leaves
L28
4AGE/4AGZE
I guess L28
doesnt rule out any rb's
specially not a forged one.
rules out most of the others though.
9000rpm rules any motor if the idiot wants it to survive for any real length of time, especially if he is actually racing it on/off at track/drags. Doesnt matter how 'built' it is. A small capacity 4 would do it easier and have half a chance of surviving, something with a big bore and short stroke.
there was no mention of a forged engine.
therefore, rules out all RB's except maybe an RB20 for a duration of 3 seconds.
The only built engine mentioned was the 4G63 which he has said is not it.
L28's like to rev (but it doesn't sound like a 6)
3s and CA18 also like to rev.
that clip doesn't sound like a 6.
it's defo a 4.
SR20 doesn't sound like that at all.
4agze ruled out.
to make it all easy, I'm going to stick with one final guess.
CA18DEZ (supercharger from a 4agze or a 1g-gze)
Tell me I'm right you southside loving bogan!!
:P
This is my mates
Just a lil game i wanna make up. this is my mates S13 take a guess of the engine and charger if it is charged set up.
be the first to get both correct and tell me and ill shout u a drink at the next Tuesday night dinner. :P
Have fun.. no cheating now. discuss it if u wish but PM me with ur correct answer. first correct answer wins.. 1 entry per person.
cheers
mark.
S13 vid was taken on private land oh and it is reving to 9000rpm and has been built:)
Mods please leave this. its just a lil competition for the QLD members no harm and is car related :(...
see bold
it's defo a 4.
4agze ruled out.
it sounds like a 6 to me, sounded like my engine before i put an exhaust on it...and the fact that you can hear it die off up the rev range leads me to think it is a stock compressor. i have seen people run 20 to nine on the track, of course it wont last f**k all time if you keep revin it there....but it still does it atm.
Sounds like an Electrolux...
bahahahaha
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
