I am in serious trouble need urgent help =( alarm stuffed my car
Ok peeps, I know that there are already alot of threads on alarms and stuff but this is kinda more serious. Seems like I got the Nemesis car alarm and it has seemed to 'STUFFED' my electronic auto transmission' on the same night that it was installed. I have retured to the ppl that have sold the alarm to me and they have denied everything that the alarm has stuffed my car. I then went to look for help
1. Auto transmissions places- They all say that my transmission is fine and the computer is fine also (So the alarm is stuffing my car while I'm driving)
2. Went to Nissan, and they weren't able to find the problem
3. Asked a alarm person (DJ Lethel mentioned him) and he does't know how to look @ the alarm :P
4. I also asked Consumer Affairs for help and they told me to get a second opinion from a alarm specialist and then comfronting Brant Car Alarm again.
So I really need your help guys, if u show me a good place or person that knows alot about alarms or know what I caan do I will be really greatful.
yes they have disconnect the alarm, but it's still giving me the problem..A auto transmission specialist told me that the alarm could be interfering with the computer in the car (maybe they put it too close?) anyway I hope u guys can help me. I dunno what to do now...
Alarm module should be in the engine bay... way out of the way of the ECU - I doubt it should be interefering with your ECU which is in the passenger footwell, however they may have stuffed other incinary wiring during the install (sounds like)
Thats as long as they have done a decent install.. it sounds like they have stuffed something up. Any reasonable place should offer to fix the problem themselves. Threaten legal action if they don't offer to fix it - any professional install should come with a lifetime guarantee as well.
Originally posted by MzDfectd
I THINK MY FRIEND WILL HAD THE SAME PROBLEM..
HERE SEE..
http://forums.melbccr.com/showflat.php?Cat...sb=5&o=&fpart=1
well his problem is not exactly the same as my problem but if his gonna get the alarm..I wouldn't recommend the installer for the Brant alarm 'Sam'.
Anyway, I'm gonna give em a call tomorrow and c if they wil remove the alarm for me.
What exactly is the auto trans doing? Not shifting? Shifting wrong? It might be just a coincidence that it happened at the same time as the alarm going in, or maybe the installer accidentally knocked something (like a plug or sensor)? Don't forget that, to run the wiring for the alarm, they usually run them right next to the factory wiring loom, so potential for installation issues is right up there...
car shifts really hard into gear 2 then goes up to 6000 rpms to change into gear 3 and I'm not even pushing hard on the accerlerator.
the installer came when I complained about the problem to them and they removed the cable to the alarm, but the car was still doing it.
I'm gonna give a diagnostic test on the car tomorrow morning.
  • 6 months later...
hey leon,
i had a thread bout some issues i been having with my auto, you replied there also 'auto issue' now that ive read this thread something has got me concerned, maybe its just a coincidence but i also have a brant alarm.
just wondering if you ever got this sorted out at all, and if so what was the prob ?
cheers mate
shannon
yeah I got it all sorted out...those damn idiots dont even know how to hook the thing up properly and 1 of the wires was f***ing my transmission.....I wasted sooo much time with that issue and got nothing out of it... I will never recommend anyone to using Brant. Also their installer is a idiot. Forgot his name though, but he was around the west area as well
Fat guy called Sam? He has fuct my doors as well. Basically, if i try to open the door while locked, it won't open when I unarm it. Also, I can't lock the drivers door as well. That guy is a twat. My auto keeps slipping out of overdrive now too, although i think it was doing that before too.
f*** man, yeah! Thats him..his really bad and a wanker as well...when did u put your alarm in? I dunno how they got such a idiot to do the installs for Brant.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
