hey i just had a problem wit my '96 r33..
i just got my new afc, a apexi neo afc..
wen for two days seemed fine..
den all of a sec.. boom!
could rev past past 2000rpm...
found out it was my afc..i reset it and i could drive..lol
so now it running lik crap..im gona take it a different tuner 2mrw..not the same place!!!!..lol
but for now, has anyone got details on der afc AIR Map..like settings wise..
wat have u set ur HI-THROTTLE & LOW-THROTTLE air map settings at..
500rpm,1000rpm,1500rpm,2000rpm...8000rpm etc..
any info would help!
i no all cars a different, diff boost settings, diff mods..etc..but any details would help, not just me but anyone wit the same problem..or similar problems..
https://www.sau.com.au/forums/topic/189934-air-map-settingswat-urs/
if you afc has reset you have probably lost all the setting in it. have a look over this thred towards the bottom:
http://www.skylinesaustralia.com/forums/t188187.html
even though it is for a safcII the settings on the neo are the same. Sensor type HW-4. SensCal 01 01. throttle arrow up.
don't worry about the hi and low throttle settings yet until you know the thing will run on an unmodified map.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
