hey guys,
im planning to get the r32.4 front conversion put on my 32 GTR, but i was wondering, is anything about it illegal? The front conversion comes with :
- fibreglass front bar,
- fibreglass conversion fenders,
- genuine R34 xenon headlights
- R34 genuine amber indicators
- carbon fibre vented bonnet (vents will be blocked as they face the windscreen :O )
Its all gonna be painted black, except the CF hood.. Any heads up would be appreciated :O
https://www.sau.com.au/forums/topic/190159-r324-front-only-conversion/
any glass panels are illegal.... so are cat backs come jan2008 (new EPA/adr compliance rules)..... who cares.
lol.. i care coz i dont wanna get a defect and have to take it off after installing it and selling my old front :P
i guess there are alot of cars around with fibreglass bodykits.. cops dont force em to take their kits off..
Trent how can they change the epa rules for older cars thou?? i though all the emmissions laws are for current model cars and not back dated. Also what would that do for the non-gen stuff that are copies of the gen stuff wouldnt that still be classed as a cat back?
technically fibreglass body panels are illegal unless they show similar crumple and crash absorption properties to the original metal... but you'll only have to deal with that if you are getting it engineered.
R34 xenon headlights are non auto levelling, so are illegal.
CF bonnet is just a fibreglass bonnet with a layer of CF on top to make you look cool, so other than running the risk of getting the wrong attention, its the same as having a fibreglass bonnet. There is a transition year (which I can't remember) after which its illegal to have fibreglass (or fake CF) bonnets but R32's should be before that date so you should be OK. Have fun trying to explain to the copper that pulls you over that your "CF look" bonnet's not real 100% CF, and therefore semi legal though.
ok cool, so the body panels wont be too big a deal..
the headlights should be ok, since so many ricers have it.. Is it possible to change the headlights to non xenon without selling my pair and buying another?
as for the "CF" bonnet, it should be ok, as long as the officer is understanding :P lol
thanks for all the help guys :rolleyes:
they came standard with xenons so quite a few people have them if they didnt get complied properly not just ricers
and im pretty sure (not 100%) that fiberglass bonnets and guards are illegal, there is one place in Queensland that has just gotten their fibreglass bonnets approved in their state (artical in the last hot 4's) as said before, to o with crumple zones
just keep your H1 bulbs and trim the housing down to suit the D2S housing of the HID lights :ninja:
put the H1 bulbs into the HID housing, it'll look ok still, they do it all the time when compliancing, make sure you keep the ballasts and HID bulbs with you though, or the compliancer has every right to destroy them
Get the cert, then put the lights back in at home :D
Not sure about the guards/bonnet though, i mean your whole car will be fibreglass at the front, there must be a way round it though, maybe borrow an R34 bonnet in steel for the compliancing? I'm sure someone won't mind driving with your CF bonnet for a weekend :P while you use theirs :)
certainly would look hot! i want to do this in the near future as well but its pointless getting the full kit as i have a 4dr :)
one thing i dont like about this kit is the front bar!!!!!! god damn its ugly.
perhaps a BN kit or something would look nice.
Edited by whyte
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
