hi all,
i was just wondering about some RB engines i have seen around.
some of them have the 6 coilpacks replaced with high tension leads running to the spark plugs instead.
has the ignition module and the coil been replaced with aftermarket units? or how is this done?
any advantages other than easier to change the plugs?
can someone please advise.
ron
https://www.sau.com.au/forums/topic/19017-new-ignition-setup/
believe this is done to allow bigger coilpacks, therefore bigger spark. Very handy if you are running CDI.
Have only seen it done on a track GTR, it was using 6 ford 6 cylinder coil packs, ie, each coilpack was used by ford on the falcons to run six sparkplugs, was hooked up to its own plug.
I have been told that just by removing the cover on the stock coilpacks will aid cooling as well (of the coilpacks)
ive seen this done using the factory coils bolted to the firewall runnin ht leads to the spark plugs ona factory computer
but i dont think u can use the bosh gt40 coils with the factory igtion system coz the gt40 coils have 2 wires + and - were as the factory system has 3 wires + and - and a signal wire tryin to find out what the signal wire does at the moment
hi,
what steve said earlier sounds right by using some Ford coils to replace. I had a look in an MSD catalog and found some modules that may work for 6 cly of course, but dunno about the cost.
i took my cover off a while a go but cannot tell any different.
but it will sure cool the packs down.
the car that i saw was stock by the way, man!!! should ve had a better look!!!!
ron
Hi guys, if you are loking at more than 750 bhp then upgrading the standard coils may be worthwhile, under that it's a waste of money.
If you are looking at more than 750 bhp, then 6 individual coil packs suitable for CDI would be the best choice. No hi tension leads as they add another area for problems. On the Motec CDI equiped race cars we use Mercury outboard coils at the plugs mounted on a fabricated rail.
Hope that helps
When you look at the age of coil packs on a R32 in particular, we need to start thinking about alternative and newer methods to ensure reliability of the vehicle if we decide to own it for a few more years.
Another benefit is the ease of changing plugs. I hate that job and im sure there are other out there that do to.
I have thought about getting my hands on a crow cams amplifier pack and wiring it into the loom so it recieves the signal from the ignition pack then power is transferred to the plugs through hi tension leads?
Not really interested in adding hi tension leads but would be keen to find a cheaper replacement for when the coils die.
I guess you could resite the coil rails to mount on the rocker cover and run very short plug leads
These cars you see running aftermarket coils are using aftermarket ECU's.
Around 1 year ago, I saw an RB with I think it was a VP coil pack running high tension leads.
A few phone calls later and I was told that it is impossible with the stock ECU.
The standard coils are good enough for around 700hp so replacing them is a waste of time and money, heat soak is what kills them a CDI is a good fix for this problem as the dwell is reduced resulting in a decrease in coil heating. The standard coils have 3 wires running to them 1 pos 1 neg and the other is a ground connection to the cyl head.
cheers
Hi guys, the standard RB ignition coils are not really designed for use with a CDI. A CDI works by repeated rapid discharges from a capacitor during a single plug firing. The standard RB coils are designed for one single discharge per firing.
So if you intend to drive the coils with a CDI, then you really should use coils designed for multiple discharges. Otherwise you are not going to see the best effect from using a CDI. The cheapest/best CDI capable coils we have found are the Mercury outboard coils I previously mentioned.
Realistically I have found a very, very low percentage of RB standard coil failures. Plus good second hand ones have proven very easy and cheap to locate. High tension lead failure is a far more likely occurrence, so I avoid them. As Mort posted, over 700 bhp and I would think seriously about CDI with on plug coils, under that and its a waste of time and money.
Hope that clarifies
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
