ur right so would it be RB20C???
as E is electronic injection
yeah and D means direct ignition or something like that....you'll prob find the E only engine has coils located somewhere else...or a dizzy or some kind. i think.
https://www.sau.com.au/forums/topic/190204-the-skyline/#findComment-3431574
my first was a "GTS Type S V Selection II"... its a mouthful
RB24S is the carby 2.4L engine so S is for carburettor, E is for electronic injection. The GXi came with a CA18i (not DE) which had a dizzy.
https://www.sau.com.au/forums/topic/190204-the-skyline/#findComment-3431672
Yeah Mark ya right...
RB is the series of engine
20/25/26/30 is the capicity of the motor
D = Double over head cam
E = EFI
T = One turbo
TT = Twin turbo
Thats basiclly it, the carby only appeared on the 2.4 litre version of the rb20 as Shan said...
Also you should be aware that when the R31 came out there were a few brought out by Tommi K called M30's
These were the first nissan hybrid engine, it was an Rb30 bottom end and an RB20 head, non turbo, first double over head cam Rb30 made back in 1986/7... :)
https://www.sau.com.au/forums/topic/190204-the-skyline/#findComment-3432083
I didnt use Google Marki, Im a true Nissan Skyline buff...
Id expect 50% of the users of SAU to know what I posted of the top of their head, its sorta common knowledge.
(Apart from the M30 bit, i used to be a R31 know it all before I could afford something newer)
I find it funny that you say your a mechanic and yet you dont know your nissan motors.
Maby you should use google first before posting as it might help make you look like you knwo what your talking about.
https://www.sau.com.au/forums/topic/190204-the-skyline/#findComment-3432112
lol tall claim saying i dnt knw nissan motors haha.. :sorcerer: seeing as i pull down a RB with my eyes closed and put it back together with silicone and chewing gum haha and i do my shit with hand tools no power crap. im old school
my bad thinking a toyota "C" was also same abreviation as what nissan use. my bad
then again i was trained by toyota and a mechanic from ADD racing so i knw nothing bout nissan engines. haha :laughing-smiley-014:
https://www.sau.com.au/forums/topic/190204-the-skyline/#findComment-3432137
You said it all in that line right there... Nuf said
im sorry are u sayin ADD is shit lol..
thats funny col cause last time i checked they wer top5 nation drift team..
and the most reputable drift workshop in QLD.. so who wouldnt want to learn from the best. :P
https://www.sau.com.au/forums/topic/190204-the-skyline/#findComment-3434104
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
