garrett turbo gt35r 62 ar
tiail 38mm westgate
plenum greddy and fuel line
n1 oil pump
forged pistons
eagle rods
acl coted bearings
split fire super direct
greddy timingbelt
tomei 252 cams
cometic theadgasket 1,5mm?
OS giken twinplate
N1 wather pump
650cc injectors
BIG ic
Big radiator
oil radiator
bigger fuel pump
Do I need to port the head?
Do I need tomei valve springs?
What more do I need.
What is going to brake first it is a drift/street car ;)
Edited by jansson
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/
You will need HUGE brakes!
Nice setup. Good to see a few more big power gtts coming along.
Definitely do valve springs and why not port the head while you are at it?
All else sounds good but make sure you have very wide rear tyres ;)
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3427856
I'm going to purch Big stoptec brakes and Nismo 1,5 way LSD
If I purch tomei valve springs how high rps can I go?
Okej I and a engine builder are going to take a good look on the head and se what to do=)
What is the weakest in the engine?
Anyting more I need to do bether?
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3430262
Have not anybody something to share
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3432727
if you are going to use it for drift i suggest u read sydney kids oil control thread and that turbo you are using is a bit laggy for drift unless u keep the comp ratio up and think about more cc's. i would also suggest a different plenum than the greddy one like a custom made one with longer runners!
u want it to rev so head work it a must also valves springs and everything done to head is a good start.
also i would use a tial 44mm-38 is too small and also 260 tomei cams that will help with midrange
thats the engine done now what about suspension and castor rods and all that shit ...r34 aint the best car for drift cheers its like taking my van to the drift track..hahahah
cheers
Edited by infected flow
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3432976
cheers
I have hks hyper max 3 coilovers cusco castor rods ray wheel etc etc
Are you sure the 44mm westgate is the right choise I do not think so.
Why longer runners?
Yes tomei 260 cams but whats springs are the best choise?
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3454901
  • 1 month later...
I put all my $$$ onto the diff being the first thing to let go :D
Also your more than likely going to get valve float given you'll be running a reasonbly high amount of boost, and using big RPM to do so.
the half shafts will snap before the diff thats for sure. it seems that with anything 300 rwkw and over your walking a fine line with the stock sized halfshafts.
swap in GTR items along with a decent LSD
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3551995
The gtr ones, are they a straight fit in, or are they fairly easy to put in?
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3553038
500whp (370ish rwkw) with a 62 rear is a pipe dream but very Nice streeter setup none the less. and the 38m gate is to small for anything over 400whp really.
R34 with the right setup is sweet for drift, a little big but stable as and far less work than a 32 or s13 chassis.
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3553094
quite a interesting thread as ive just put my car in for a simliar setup, as stated above i dont think a .62 housing will meet 500rwhp.
im going to be running a 3.0L setup for the extra torque, so wat do u guys recommend diff wise for mainly street use. occasional drag.
also jason did u modify a gtr greddy plenum to fit the neo? i dont believe there are any bolt on greedy plenums
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3553114
as for power i reckon closer to 400whp.
std diff will be fine (just shim it or put a centre in it)... alot of hype up there for nothing..... we broke one diff in 3 years. i will post you a link for the plenum, i have done a few just use the R33 one it bolts straight up just a few small things need changing accessory wise. piece of piss.
http://www.skylinesaustralia.com/forums/In...4+plenum+greddy
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3553119
std diff will be fine (just shim it or put a centre in it)... alot of hype up there for nothing..... we broke one diff in 3 years. i will post you a link for the plenum, i have done a few just use the R33 one it bolts straight up just a few small things need changing accessory wise. piece of piss. as for power i reckon closer to 400whp.
greddy plenums only support aroun 400whp???? i thought it be alot higher, plazmamans plenums (direct bold for neo) support 1000+ i believe, although the price is that high aswell lol
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3553129
no i reckon a GT35R .6 will support around 400rwhp.... the plenums are good for at least double that.
https://www.sau.com.au/forums/topic/190351-r34-neo-500whp/#findComment-3553173
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
