On Saturday night i was on a cruise with a few sau members and hicas kicked in at 80km and caused me to hit the gutter and mount the island funny now but not at the time, broke my front bar nothing that a bit of race tape and trick helping me couldnt fix but i didn't think it could just come on like that anyway very lucky to escape with just that damage
https://www.sau.com.au/forums/topic/190453-i-hate-hicas/
  • Replies 54
Posted Images
The hicas is fairly invisible at low speeds i.e 80km/h.
I've found it to be a little worrying at higher speeds but its more so like riding a horse; just go with it and its fine.
It shouldn't cause you to hit a gutter etc. If it does I suspect something is up with the hicas.
Mine recently has started moving around a little and is a result of a stuffed hicas rack. Jack the car up and you may find the wheels can be wobbled from side to side excessively.
Mine mostly plays up on acceleration as it tramlines from the rear essentially steering from the rear; makes for very nervous hard throttle lane changes.
Has the subframe/hicas been removed at some point? Maybe there's an airlock in there?
https://www.sau.com.au/forums/topic/190453-i-hate-hicas/#findComment-3429705
thanks hun im about to put it on a hoist just to make sure that nothing else is damaged and ill get my mate to look at that, i was going around a bend to the left and it just went out from under me so i went to power out of it but that was the bad move i think cause that is what threw me towards the gutter what do you think i should have done?
https://www.sau.com.au/forums/topic/190453-i-hate-hicas/#findComment-3429718
I'm with Cubes, HICAS just makes the car feel vaig*(spelling) when you're really on the edge, it shouldn't make you turn into the gutter. There may be a problem somewhere.
However, it's not because of an airlock etc. as the hicas on the 33 is all electrical so there are no hydraulic lines :cheers:
Look for a post in the diy section about HICAS diagnostics, there is a self diagnostic program that you can access by doing certain things, might help find the problem
Edited by Race__24
https://www.sau.com.au/forums/topic/190453-i-hate-hicas/#findComment-3429724
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
