  • Replies 54
Posted Images
:turned: yay no damage under the car :w00t:
as for the hicas its going in the bin and a lock bar is going in it's place thanks sambo33 sounds like a plane
no worries, i got mine from greenline, but it looks like theres some for sale on the forums too
http://www.skylinesaustralia.com/forums/t183517.html
thanks hun im about to put it on a hoist just to make sure that nothing else is damaged and ill get my mate to look at that, i was going around a bend to the left and it just went out from under me so i went to power out of it but that was the bad move i think cause that is what threw me towards the gutter what do you think i should have done?
Look, I wasn't there, but it sounds to me like you simply went round the corner too quick and lost it.
HICAS only moves +/-0.5 degrees, and as said just leaves you a bit of a "vague" feeling on the edge.
It's not VTEC yo! and doesn't go about randomly and violently kicking in under normal operation.
Sorry to hear about ur car Kellie... cable ties & gaffa tape ftw !!
my hicas is a bit knackered, just like with Cubes under hard acceleration it can apply itself, making me have to counter steer slightly to the left... and it returns under deceleration, pretty sure the rack or the rear pump is fkd. Just gotta find time to rip out all the unwanted pump and lines when i chuck in my lock bar and lose that extra 30kg :P the guides say it takes a few hours.... so im gonna allow days :rolleyes:
So let me see if i got this right, You own a R33 Turbo RB25 RWD car, You were traveling around a corner, and ur car went sideways, and gave it more stick, and u lost it into a gutter, and ur blaming hicas...
Edited by silverbulletR33
I was in a 32 awhile ago, we were driving in a straight line, I was in the back and I felt a sudden side shift, at the same time i asked Wtfwt the driver said the hicas light has come on, it has happened a few very random times before.
I ditched mine as well :)
i had a 33 gtst and another mates one too, that over 80k's the hicas went crazy. Id be correcting myslf on a straight road.
Turned out to be the little plastic disc behind the steering wheel was crooked.
So hicas does stuff up, you cant assume that a girl (kellie) does not know how to drive, and just put it down to that.
I say good on her, being out there cruising learning her car, its the only way to learn is to know your limits.
Some ppl are bagging her and i bet she could drive better than some ppl on here, at least she is out there doing it.
Thats my 2 cents
mike
I've never had an issue with my HICAS so I don't really know what it's like when it goes wild but to say that the rear wheels turning half a degree has caused you to crash is ridiculous.
No offense (well... not much anyway)
Race__24....toolmaker? fitter and turner?
hey i love that design...if it was cnc do you still have the program??? hehe.
Yeah mate, toolie by trade but working in aerospace now. I don't have the program but can write you one if you want.
i got mine off of Sherwin (NV_NO1), hes quick and is a good seller.
ive got a 180, so mine is a bit different, but im sure the symptoms of malfunctioning hicas would be similar.
before i locked my hicas it actually seemed to have a mind of its own. at low speed, as others have said, it was alright, i could still notice it, but could handle it. it wasnt until i started going 100km/h+ that it really got bad.
it was actually dangerous. the back end just felt like it had a mind of its own. slight corners would make it go nuts and all over the place, and have fun trying to turn abit sharper under speed. there was no way of knowing what it would do.
r33s have it easy when it comes to locking it, as others have mentioned it is electrical.
on s13s it is mechanical. took me a couple of hours to get the tie rod ends out, lock bar in, remove all the lines to the front, remove the actual hicas pump, and then finally run a loop from the outlet that goes to the hicas cradle to the inlet that brings it back.
then there was the hunt to find the right wire to cut to get the light to go out on the dash.
worth it though, the before and after difference is really very good. but thats coming from hicas that had a mind of its own. if it was working correctly im sure it would have served its purpose properly.
not sure bout 33's but i gots 32 that had hicas but got taken out n an S13 rear cradle got put in.
bolts straight up n is shyt load lighter,
i would recomend that to ppl if they want hicas gone in there 32 for good
Possibly a weakness with the hicas elec setup.
Mines only recently started playing up but granted I have had the car for ~6years and travelled ~181,000km's (total odo 248,000) so she's done well.
The cars still a million times better than the old VS 5ltr 5speed I bought that was near new back in 1999 with low km's. From day one the interior rattled, had alternator, inlet manifold leaks, gearbox, diff and rear IRS subframe problems. The little ol' R32 has zero rattles, still drives well, still on the same alt, power steer pump etc.
thanks to those that slaged me yeah i was going fast but you all were not on the cruise and i didnt ask for you all to be nasty so thanks :P
love all of you that were helpful and gave me some tips on how to fix/evaluate the problem :P
thanks michael for sticking up for me :D
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
