Heya all,
my boost controller goes on holidays at random intervals and quite often I'm overboosting up to 1.8bar :rolleyes:
booted it on the freeway in 4th today to overtake a truck and it over boosted from the time it took to get from 100ks to 160ks, which wasnt that long I spose...
I keep fiddling with the controller, its a GReedy prospec B (analogue) dual stage EBC
while it has been dialed in at .9-1bar it always seems to fluctuate, sometimes working perfectly sometimes overboosting like a mofo.
how long before an exaust turbine falls off?
https://www.sau.com.au/forums/topic/190551-stock-r32-gtr-turbos/
How long is a piece of string?
There is no clear-cut answer to a question like that dude.
No-one knows. :rolleyes:
thought that might be the case..
I have been advised that its not so much of a problem in lower gears because your always changing and they dont get a great deal of time spinning at those higher rpm's, but was told to beware gunning it on the freeway if its overboosting as it will die pretty fast..
was kinda interested as to just how terminal boosting stock GTR turbs past 1.2 bar or so realy is (ie, do they die realy fast?)
well how it was explained to me (and I cant recall the exact rpm's) was that the stock turbo's spin at like 100 - 170k rpms and then you enter the danger area of 200k+ rpm at over 1bar, I was also told that after 1bar the small stock turbines turbo's will spin an extra 50k rpm or so for every .2bar making upping things a real stain on the relitivly weak ceramic exaust wheel.
does this sound right, or was I fed a heap of bullsh!t?
I had one go at 12psi, it hurt the rings on piston 3 too.
Leave them the hell alone, sure there are people who punt about with 14 psi but, there are lots of people who did that and had to rebuild an Rb26 (not a cheap experience).
Consider low boost a cost saving measure so you can save for replacement GT-SS/N1/'insert steel wheel turbo type here'
or just set your boost controller properly??????
And by that you mean using the stock one at factory boost, right?
My boost control was as good as you get.
14psi on stock 'old' ceramic GTR turbos = gambling with your motor.
I seem to recall this sort of thread coming up in the distant past with a large number of examples of turbo failure experience poping up in it.
My stock turbos were ran at 14.7psi all day everyday and it has slightly lesss than 100 000k's on it. When i recently changed the turbos over a couple weeks ago they were still in great nick. I've heard of people blowing them as soon as they run 1 bar and others that they never go at 1bar. It's just luck of the draw i guess.
so your saying you ran 100,000kms on 1 bar?
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
