Went in for a tune of my RB26 the other day and had lots of problems...
Most are a easy fix but one niggling on is the fact that my d-jetro map sensors are bottom lining at 20psi and I'm told that they generally max out at 26psi...
Any ideas why this is happening?!?
Cheers
Simon
https://www.sau.com.au/forums/topic/190702-power-fc-d-jetro-problem/
where is the pressure source taken from? i have had issue's when not taking the source from the actual throttle bodys (bit of a pain but worth the effort)... hooking up to the balance bar tends to cause a few issues.
where is the pressure source taken from? i have had issue's when not taking the source from the actual throttle bodys... hooking up to the balance bar tends to cause a few issues.
the intake manifold just before the throttle bodys?!?
Edited by Cerbera
before head and butterflies or between plenum and butterflies? it should be between head and throttle plates as shown in install manual.
ah yeah so thats the scale then and correction
that doesnt mean your maxing the map sensors
have you got a data log of the run?
check out what voltage PIM1/PIM2 get to, if they hit 5v they are maxing
sorry to hijack ur thread cerbera but i thought since ur on the topic of D jetro's i got a quick simple question.
they only made these for the GTR right? aint none of these got GTST or GTTs?
You can modify the ECU loom for the R33 GTST to be able to use the D-Jetro. I Don't know if this is the same for the R34 GTT (probably depends on the ECU plug shape as much as anything).
yeah RB26 D-Jetro can be used in R32, R33 and Z32 (300zx) but R34 GTT has a totally diff ecu plug.
did you see my last post?
is PIM1/PIM2 actaully maxing at 5v?
took stupid thing for a drive last night and boosted in 3rd gear to 23psi and the PIM voltage read 4.867V
this was only just on boost as the car is only rwd at the moment and likes to smoke 265's when it comes on boost and female passengers tend to get scared!!!
is this classified as close enough to 5V?!? maxing out?!?
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
