  • Replies 49
hey guys when the battery light comes on while the car is running, it has nothin to do with the battery, it means there is a problem with the charing system, usually the alternator or wiring to alternator, i see alot of people do this mistake, just let us know how u go dude.
Mine was being a bit difficult a while ago and cutting out etc. Was really frustrating, turned out to be a dodgy AFM and crank angle sensor, try swap them out with a mates if u can and go for a decent drive and see if that rectifies it. Goodluck buddy
Hi
I am having the exact same problem too...I drive a 94 GTS-T. It will drive fine but all of a sudden whenever i press break the engine will just stop. It ususally happens when it's really hot, like when i drive in the evening it will run fine but in the afternoon it will stop more often.
Hi
Is it an instant stop? Or does it go down to idle then stall?
id say def not the coil packs mate..does the car start again straight after it stalls or do you have to leave it for a while..?..sounds like either the crank angle sensor or the ignition module.!
Mien does this when pulling up to a roundabout/lights corner and i am breaking/shifting down. Sometimes the revs will just drop lower than it should and it will die on me. When this starts to happen (usually after the car warms up it'll happen every now and then) the idle will become a little rougher
...aac valve sound like the problem? ill be taking it to a proper workshop soon i think, the last dickhead to touch my car charged me an arm and a leg for a major service and this problem still occurs :ermm:
...aac valve sound like the problem? ill be taking it to a proper workshop soon i think, the last dickhead to touch my car charged me an arm and a leg for a major service and this problem still occurs :(
Check over your intercooler piping before bringing it to any shop. It could be leaking and causing the stalling.
any advice to do this properly? I guess i have to take the front bar off and get right down there but how do i check for leaks accurately?
Just check over your piping clamps. See if they're all tight.
Hi Thanks for your response, sorry I was away so couldn't reply earlier. As soon as i press break it stalls...the engine stops.
I can start the car immedietely using the key or just using the 2nd gear.
common cause of stalling is an intake leak like an aftermarket blow-off valve or a loost intercooler clamp
common cause of cutting out when the engine is warm in the AFM
find out whether your car stalls or cuts out. if it cuts out, swap the AFM i guarantee you its the problem
all the cooler piping in the engine bay was fine, i couldnt get the plugs off the grille to get the front bar off to get right in there and underneath to check those clamps tho lol
i have no friends with skylines to test afm, think im just gonna have to bite the bullet and see a quality garage its breaking my heart
If you have working eyes and hands and can read english, you can fix the AFM issue for yourself.
http://www.skylinesaustralia.com/forums/Fi...p;hl=SOLDER+AFM
It'll cost you time and a about $30 for soldering iron and solder and sealant (if you don't already have any of those.)
there are pics and stright forward instrucitons of what to do.
anyone who buys a skyline should do a handful of things as part of the first service I think.
1.) new copper spark plugs gapged at 0.8mm
2.) tape up coil packs with good electrical tape (or buy that silicon shit for a bit more money)
3.) Clean AAC valve.
4.) Clean AFM
5.) Re-solder AFM internal points
6.) new nissan paper ai filter element for stock air box
these along with new oil and oil filter, new fuel filter, will see a brand new car in most instances... especially if you've just bought a stock or near stock skyline which is 10-19 years old.
it will cost you bugger all in the grand scheme of things and will probably solve many little bullshit issues these cars have.
MAte,
When it stalls, I can restart the car and it drives fine again...
UPDATE: after swapping the battery; I thought this fixed the problem but no good... although it happens a tad less, still occurs... I'll drive nicely and then a couple of hours later, it would stall... then I restart and it would work fine again....
I think it's the cranke senor and the ignition modulle or the AFM - I will bring this to either Chasers or Nismo Motors in a couple of weeks.... do you guys think this will be costly to fix AND would the mechanic know how to fix this?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
