Hi guys,
After my radiator build and my surge tank build, I thought i'd show you the plenum i'm building, or what I have so far atleast.
It's an RB20DE bottom half with the runners cut off, I've then welded in 50.8x3mm wall 55mm long extensions then welded on 5mm plate as my backing.. I haven't had much time to do much else yet, but I'll get onto the rest soon.. but I thought id give you some tease pictures..
I cleaned the plenum up, wire buffed the gasket goop off and used the chemical I normally use to clean alloy with.. Before welding it all together, I preheated it in our big bake oven to 380deg c for 15 minutes to stop any potential warpage.
Anyway, onto the porn..
As my last posts of the stuff i've made, comments, complaints or anything..
Thanks,
Scott
Edited by salival
https://www.sau.com.au/forums/topic/191089-r32-plenum-makings/
looks the good so far.
u planning on testing it after your done?
Hiya,
I'll pressure test it to 25psi.. but flow test? no..
It's only a poxy rb20.. I mainly want it for the look and the reduced pipe work.. I do all this work on saturdays at my work.. so it's costing me nothing (including materials)
mate u might wanna throw some trumpets on each runner to increase air velocity/speed/distribution
I'm not using trumpets on this particular one..
I've welded inside/outside of each runner where it meets the backing plate.. I'm going to machine a radius on each runner so it merges nicely..
thats exactly how i want to make my rb20 plenum, i just need an aluminium welder at work... damn not having one anymore...!!
  • 1 month later...
after doing some research i learnt that Actually flows more then having internal trumpets, the advantage that trumpets have is it has more air velocity and the air distribution is more even threw all cylinders
alot if not all of the jap brand plenums do not use thrumpets as they are more worried about air flow
you will find that a radiussed bellmouth sitting on your base is the best for flow, which is the main reason why people go for a different plenum.
greedy 2jz, jun sr20 & maybe greedy rb26 all have raised bellmouths
  • 4 weeks later...
I want to see more! Im actually doing this same thing. Im using trumpets but am going to make the very outer tip of the trumpet flush with the plate instead of sticking out into the plenum. Its like what your doing but with less machining......hopefully. Are you putting yours into a 180sx? Im wondering how far mine can stick out without hitting the strut tower and giving me good clearance? Very nice job on the tig work too!
whats the best way of cutting the cast runners of the flange??
How i've done this on the few that i've made has been to use a 'woodworker's' bandsaw then facemill all the runners to a uniform height. Usually at a 10deg. angle down to help with clearence around the brake booster and clutch master.
Trumpets / Bellmouths are an absolute must!! I made a die from 75mm BMS bar then pressed it into the alloy tube. (before welding)
Edited by Nigel.
i personally think u should have welded it on both sides (inside and out side) so that u can machine down the welds on the out side of the plenum so it looks like its all one peice from the out side
Ah, but you see.. there is a flaw in your plan..
I love welds :(
im at this same point with my manifold,. what are u going to do about the step in the runners? what tool u gonna use to even them out? cuz i did the same thing. used 2" tubes for runners but the stock runner is about 1.90" where as the tubes are perfect 2"? is there some kind of grinding tool that has some length to be able to get inside?
Edited by (--MeUnVmosT---)
  • 4 weeks later...
you guys are doing a great job..
I have started my project (11 months ago! lol) where i was using trumpets inside the plenum.
however, I have been looking at using shower form injection. This is where the injectors are mounted directly above, facing down the inside of the trumpet.
Indy cars do this. they say it helps build topend power.
The idea is that the 'shower' of fuel helps capture extra air and force it into the cylinder, this also gives better atomization.. which should mean more power for the same amount of fuel..
My plan is to use a shallower plenum with similar volume, with indents in the roof of the plenum above the trumpets for the injector bosses. LOTS of work! My current problem is tring to get manifold runner length while still leaving space for the injectors. I have been measuring and calculating how well it will work if i do a plenum that sits ontop of the existing runners.. I am concerned that the 'shower' of fuel may stall with the longer bent runners. i know somebody with a flow bench, so I have not touched the project until I do more research. cos i currently have to many variables.
did that hurt anybodies head? did mine!
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
