hi mate, I can't confirm but they may well be interchangeable.
I got a replacement caster rod for my 32 gtr which I was told was a gtr, it was a perfect fit but was about 1cm narrower where the bush goes through. I am thinking it was probably a 32 gtst one. If so, the gtst one fits fine on a gtr, and probably vice versa. Also left and right are interchangeable you just need to knock the studs out and put them back in from the other side
why do you need new ones? dead bushes or some problem with the actual rods
https://www.sau.com.au/forums/topic/191130-caster-rods/#findComment-3439632
Thanks for that info man.
I need them for RWC, they are slightly worn apparently.
I have ordered after-market caster rods, but they have no arrived yet, so I sorta need new ones urgently so I can get my car rego'd :P
Reason I asked why GTR ones will fit is because my cousin just pulled his GTR ones out, and replaced them with CUSCO ones. His bushes are in pretty good working order, so I thought if we could interchange them from GTR to GTST for a while, that would help me out and save me some $money.
I guess I will just pull mine out tomorrow and compare them to his GTR ones, but I thought GTR would be different for sure due to the altessa setup.
No they are not the GTR are different because they are 4WD
the bushes should be the same.
Need a more definite answer than that man, seems like your just guessing?
You know that for a fact or are you guessing?
I know the R33 GTR and GTST caster rods are the same, not sure about the 32's
Thanks Al. You wouldn't know if R33 caster rods fit R32?
Edited by abu
https://www.sau.com.au/forums/topic/191130-caster-rods/#findComment-3439807
33 is different, they are straight not slightly bent for a start.
6 nuts to fit both of the gtr ones. If the bush at the front of the subframe fits the rest will.
It is cheap and easy to replace the bushes though, adjustable arms aren't a great solution because they come with rose jointed rod ends instead of bushes like standard - they will wear and start to get noisey much sooner than the standard style.
https://www.sau.com.au/forums/topic/191130-caster-rods/#findComment-3439839
The Noltec website lists the GTR and GTS-t having different width bushes.
82.5mm for the GTR
71.5mm for the GTS-t
Pretty much just confirms Duncan's findings. :O
On the note of adjustable arms and sphericals, Noltec also make an adjustable arm that uses bushes instead of sphericals, so would be a good solution if you're after a bit more adjustment on a still road driven car.
Down side is they retail for $494.64...
http://noltecsuspension.com/popproduct.php...32++++5%2F89-93
Says that they're only suitable for GTR, but I'm sure you could get them to put the shorter GTS-t bush in there instead. :)
Edited by salad
https://www.sau.com.au/forums/topic/191130-caster-rods/#findComment-3439853
Thanks for all the replies guys, I just don't have time to stuff around so I want to get it right the first time.
My best bet will be to fine a set of R32/S13 caster rods with good bushes, or just to buy a set of R32/S13 caster rods and get new bushes put on. That way its just out with the old ones and in with the new set, no stuffing around.
Yes I'm sure the GTS-4 and GTR are the same but
the GTS isn't.The arms are different
Yeah the front suspension for the GTR and GTS4's are the same because of the altessa system.
Edited by abu
https://www.sau.com.au/forums/topic/191130-caster-rods/#findComment-3439971
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
