to a degree pressure maps and numbers can get you close but throughout time man has always fallen back on the age old way, "suck it and see". Personally, I'm not a big fan of instant boost, which is why I've steered slowly away from small A/R turbines as they just run out of puff too early. I'm told the 3076 with .63 housing will give brilliant results but I know it will be limited by the small housing and stop around the 250-260kw mark. Besides, if the car is barely moving and hits boost hard it's wheel spin city......instantly. No, I think the .82 housing will be perfect but, the compressor, now, thats another story. Guess I'll find out soon enough.
  • Replies 148
Skylinecouple;
I wouldn't be concerned if power comes on too hard; a little time spent on the dyno and its easy as pie to tune it to transition softer.
All though that spoils have the fun with improving your throttle control skills. :whistling:
The 3ltr with the GT30 has some pretty mean mid range power; after a few tweaks am now finally able to get all of second gears power down.
I still find it difficult to get off the line clean in first, usually short shift in to second and let the early boost build soak it up.
The 12mm subframe rake has made a massive improvement to traction; even when it is spinning the arse sits down and accelerates the car fairly quick.
Prior to the rake it felt as if the wheels where just dangling in the air wheel spinning and road speed was hardly increasing.
  • 3 weeks later...
  • 7 months later...
I thought rather than start a whole new post I'd resurrect my old decision post and continue from there. Hey Cubes, thanks for the PM. Yes there is a problem with boost falling away because we didn't put enough tension on the actuator. I know for a fact having seen the behaviour on the dyno that this power was achieved with 16lbs not 19. On the actuator only we had 243kws at 13lbs. I think if I put a bit more tension in to hold it at, say, 18lbs all the way to redline we could see 270kws very comfortably. You see Yavus had it up another 15kws but we agreed for track work to make it very safe. I know I can thrash it on a hot day and bad batch of fuel and not worry. Couple of issues we need to address is the dump not being 3" but just under as it has a slipper pipe which has to be slightly smaller to fit into the 3" exhaust. The turbine outlet alone is 3" and the waste gate is I think 1 & a half. So we will saw off the end of the dump and weld on a 3.5" or 4". Also working on a fully enclosed alloy air box with temp proof lining, should look good and with the biggest air filter I can find may make breathing easier.
p><p><a  href=http://www.skylinesaustralia.com/forums/uploads/1215946577/gallery_23164_2695_13951.jpg' alt='gallery_23164_2695_13951.jpg'>
Congratulations on the good overall result. Similar to a few guys with the HKS 2835 Pro S, but I think they might be tuned/boosted a bit more aggressively. Be interested to see what it would look/go like if you let the tuner play further.
I'd thought the fuelling was richer than that. A consistent 12.2 looks pretty tidy to me :P
Depending on how quiet (restrictive) the muffling is, you may find the boost drop related to rising back pressure within the exhaust. My removable baffle 20kW, but is worth it to keep road legal and also avoid tinnitus. The odd thing is that the increased back pressure from it only stops it making more maximum power and does not induce a sharp nose over.
Shape of the graph to me looks great - very linear looking and holds maximum across a decent range without falling away. It's good to know that you have extra grunt to access if you wanted to play with ignition. For the odd track day would it be better/desirable to use an octane boost eg. toluene and take advantage of it? That would take care of concerns about the dreaded knock and give a few more herbs. It's pretty evident that the ignition mapping is the only thing holding it back.
A 3.5 inch dump/front pipe will fit in, but reasonably tight. 3 inch should be ample at the power level though. With your fabrication skills try doing the dump with a half-pipe attached similar to the HKS Pro S arrangement. I split open a 3 inch bend and shaped to suit. That would allow a bigger venting volume for the wastegate and perhaps reduced turbulence.
Edited by Dale FZ1
Have to agree on the dump pipe. May just fit a 3.5" pipe in there though, seems to be enough room. There is definately more room to play with the timing but will put another full turn on the actuator first and make sure the bottom line is actually 14lbs. I have a thing about track day fuel mixing, Ferrari or Lambo's don't have to worry about it so I don't want to either. I always drive on the full boost setting because I want a car that is fast all day every day, not to use it but for the satisfaction of having nothing to prove. Which brings me to the driving performance.
The boost comes on fast, how do I explain, boost hits at 3,500rpm but it happens so quickly like as quick as you push the go pedal it has a one second pause before it's all happening. And when it hits, wow ! Each gear there is no pause or lag and more to the point the lag is non existant at part throttle. As long as revs are above 3,500rpm you have instant response. I guess this is attributed to the small compressor compared to the 3076, or more to the point the smaller comp housing. It just seems to have response everywhere. As for fuel consumption the improvement is great. Went down the coast and did 300k's with half a tank. Have done a hundred k's around town after filling up again and only just moved off full. Thank you to Yavus as he did a little fine tuning at lower revs and part throttle. All up very happy but room to play further then work on emissions and fuel consuption further.
Would I get the 3071 again ? Hmmm, yes I think so but with cams before tune. Look, I know I'm going to put cams in, I can't stop changing stuff, so that will be the next step. How about 256inlet and 264 exhaust ?
The hks 256/264 cams are good.
They work for me. I'm not saying you need them as you could probably max the turbo with out them but you would make your 260rwkw with less boost, with a slight trade off in light throttle drivability around the 2k rpm mark.
Good for a track nugget if you want to look at it that way :blink:
As I said, I can't stop changing stuff. Cams are just a matter of time. Now if I could just get some really big brakes......
Some Bride seats, rear tower brace since nobody makes them for a 4 door, and still working on the rear diffuser. Oh, and a forward facing intake.
I went with some cheapo 265/263 9mm lift regrinds (221degree @ 0.050"). I've only taken it to 5k but on the same boost I'm now seeing 4.93volts from the z32 vs 4.78volts previously.
Hasn't lost anything down low only feels smoother a few hundred rpm off idle which makes it easier to drive around car parks as the throttle isn't as touchy/lungy in first.
Tune is next week :D Some sleepless nights ahead.
Never thought of regrinds, if I kept the same rev limit they shouldn't break, should they ? In the old days we reground cams all the time and never snapped one. let me know how it turns out.
Tighe cams appear to do decent ones.
rbman went with the 708c 254 8.5mm lift (214 @ 0.050") cams and picked up 26rwkw on the 1psi less.
simonr32 went the same as myself and with the std lca's on the rb25det picked up a little over 30rwkw on the same boost. then pushed in some overlap picked up 20rwkw through the mid range and dropped ~10rwkw up top.
His jumped from 260rwkw to 290 something rwkw on the same boost with the gt3071 .7 IW a/r.
Can you tell me which rear housing to get any other information you can give me.
I am getting it from GCG.
Hi.
I have the .82 housing and absolutely love it. No problems with boost control at all. That is why I went away from the .63 as too many have had boost spiking or boost continuing to climb because the internal wastegate can't flow enough. I was concerned about lag so went with the smaller 71mm comp wheel too get it to boost ealier and now very happy. If you wanted more power I would suggest the 3076 as it will make the power at lower boost. Bare in mind I will wind the actuator in a little further to hold the wastegate closed for a steady 18lbs at full revs. Notice the current boost is dying off to 16lbs from an initial 19lbs. By the way, the .82 will allow the car to make more power as revs climb so I don't get wheel spin the moment I floor it. That was so frustrating with the GCG high flow. Get the 20mm spacer for the manifold from GCG as it will give you good clearance for the comp housing. If you get the 3071 or 3076 you will need a 4" joiner from turbo to intake then 4" custom alloy pipe to 3" then 3" joiner to AFM. Make sure you get a 3.5" or 4" dump to weld onto the exhaust flange from the turbo housing or as Luis from Drifty Garage did with mine was to weld 3" then 2" piggy backed on that similar to HKS. Actually, Luis will do the lot if your unsure for about $1200 to 1300. If you can leave the car off the road for a week or two then do it at home. I have to work so not an option. Hope you go ahead.
Regards,
Gary.
I had mine tuned.. no issues with boost creep but plenty with boost drop. :)
Pushed in 19psi through the mid that would tail off to 17psi by peak power.
Tuner seems to think its airflow restricted. 2" FMIC piping + smallish FMIC + std airbox as the almost certian culprit.
3" bell mouth dump.
Power jumped to 302rwkw at 17psi massive mid range gains (~260rwkw at 4000rpm) that actually hooks up damn well due to the progressive nature of the gt30 + the boost controller setup sedately. :D
Funny how yours is behaving exactly like mine. I have an initial 19lbs then tapers off to 16lbs. Your cooler piping is killing you and for God's sake get yourself a Hybrid cooler and nothing else, look inside one and you can see an extra 20kws. My Just Jap cooler was great for 230-250kws but then you need something else. When you put the two together there is a clear difference in tube size and therefore flow. Plus an extra tube, 15 I think from the JJ 14 tube. I was lucky to pick it up as a return to the factory then repaired it and weld on new brackets. How much ? $100.
You can have my old cooler if you want but only if it is better than what you have. It's a bar and plate. $50 for you. Piping kit should be everywhere. Just Jap ?
Yeah the standard airbox has to go, Do I hear Blitz or similar ? Recently picked up a few sheets of alloy in 1.2mm for $15 so will get it done soon. Need the biggest filter I can find.
My core isn't actually too bad. 450x300x90 I've been told to stick with it (its an old spearco bar/plate core) and simply weld 2.5" outlets on to it. But it is a tad short....
Piping I'll have custom stuff done to retain that std factory look.
I really think the taper is most influenced by the 1bar actuator as I experienced the same thing when making less power on the std cams. No doubt the cooler piping and std airbox/filter is hurting it a tad. :worship:
The offer is much appreciated but its all sorted. :D
No worries, yours at 90mm is plenty of flow and I doubt 150mm shorter would make a difference in temps. So what are you saying about the actuator ? 1bar not enough ? If so, I need to get a stronger one. Is there a 17lb actuator ?
I think the best way to go here would be to free up the air inlet and see if there is still a drop in boost then go for bigger actuator. I really would like to see boost stay at a perfect 18lbs across the rev range. The only way I can see to check which is causing the problem is to watch the waste gate during a power run and see when it starts to open. I should have taken the lid off the box to see if there was a restriction. I never had a problem with 220kws. Dave, how is your 16lb actuator holding boost, do you have a standard airbox ?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
