specs, spool rods, cp flat top pistons, around 8.1 . crank polished and balanced,oil restrictor fitted.one oil gallery blocked off, trust sump, n1 oil pump, oilreturn rear of head back to sump.etc
http://s212.photobucket.com/albums/cc220/rockabillyrb30/
Edited by rockabilly
oh wait up did you drop it in with the gear box still in the car??? i have a gts4 with a gtr gear box so i have the same crap to go through as you just have. how long did it take ya?
hi mate took me 4 hours from start to finish. had to drop the anti roll bar and power steering cooler, but that was because i have a trust sump extension. i lined the gearbox input shaft up with the clutch then with a jack dropped the gearbox mount down and slid the engine on,quite easy really.
yea im having all sorts of trouble with mine. first time ive ever done anything like this. and i seem to suck at it so far. when you say aligned the shaft with the clutch is there some sort of an extension tool that u can slide on the spline of the shaft an then stick the other end into the clutch? eeeergh... i just know in the morning when i wake up im going to be up for headaches. really need a second person to work the crane while ya line it up. how long was your car off the road? also it looks like you rebuilt that yourself?? i take it your a mechanic then?
hi mate,no hang the engine off the crane so it slopes slightly rearwards. then lower in and guide the front shaft of the gearbox into the clutch then lower it in. you need to lower the gearbox rear so its at the same angle as the engine. then lower the engine in so it lines up.as you lower push the engine onto the gearbox keeping it all lined up. no i am not a mechanic, but yes i did build mine myself.. bernie
hey man
there is such thing as a clutch alignment tool, the best tool i have ever made was when i cut the front shaft off the front of my Nissan Blue Bird gearbox which i would put in the clutch and slide into the spiggot bush then tighten the clutch and make sure the shaft can slip in and out easily then your set for putting the box in properly in the car, it has to be nearly 100% to slide in first go.
fired the old girl up today, no water in her just a quick 5 mins,went first time on the button, no oil leaks just a little raspy for me,could be the forgies being new and all, will see what it like when the water goes in and she runs longer,, oil pressure 100 psi on 20/50 asda special
just done a 10 mile drive in it. i tell you guys these motors are totally different to drive than a 26, and the sound from my exhaust is unbelievable. smooth aswell. i get positive boost on the avcr from 2000 rpm any gear. thats with a turbo rated to 700bhp. well chuffed. when its run in and opened up ,man it will go some.its trying to go now and its only done 11miles.lol
well its done 60 miles now on the crap 20/50 multigrade oil, been to 1.1 bar @ 5500 rpm on that oil. just dropped the oil and put some mineral 15/50,s in will run that for a hundred and fifty miles and that will be the run in done..probably gonna be jan 4 when it gets mapped as the tuners nearby are all fully booked and i cant have time off in dec.
Sounds ace. Very well presented and good luck.
Hopefully my rb25/30 will be finished and on the road before Christmas.
Just something i noticed:
You air pod/filter has a reducer cone, then you have a silicon hose attached to increase the size to match the intake pipe. Wouldn't you be better off to remove the pod reducer cone and fabricate another cone to match the pod diameter and the intake pipe. Just thinking you may be causing some minor restrictions with the current set-up.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
