Hi guys,
I'm at the stage where I'm in a position where I have to sell my car due to financial reasons.
I'm asking for $16,000 - do you think that is reasonable for my R33 GtsT?
So here are some details
1996 R33 S2 GTS-T
98,000+ km
Tein coilovers
18" Work emotion wheels
Turbo back exhaust
Splitfire coilpacks
Pictures are here on members rides (scroll down abit)
Edited by S T A R 3 3
https://www.sau.com.au/forums/topic/191498-help-with-buying-a-car/
  • Replies 41
If its still as clean and in good condition as in the pictures you posted I think its a good price to be asking with such low Km and modifications, thats what I paid for mine a couple of months ago.
If you need or want to get rid of the Work CR Kai's before you sell the car PM me and I'll probably buy them depending on condition.
There is someone here in Canberra who travels to Autostyle in Sydney to do their engineering... AutoStyle said they would let me get it done for what it costs them (it was a car I was looking at in their shop) and I thought they said about $500/$550. They would normally put mark-up on that if it wasn't one of their cars.
They didn't give me a name of the guy down here, but if someone knows who he is, it might be worth a try. You could always call them and ask who they use for engineering.
My brother had to get an engineer cirt for his coilovers just recently. Ray at Canberra Motorworks did it, I think it cost him around $350. I'm pretty sure the price varies depending on your mods and how much work the engineer has to do. I might be wrong though.
cool thanks guys! I'm only asking because my old man wants to get a ute, but I want him to get one of these bad boys!
I can only assume that these aren't straight off the showroom floor, so they would have to be engineered to be 20ft off the ground.
I dont want him to if it causes him all the grief of DICKSon.
I contacted the seller of the above testosterone filled hilux and asked whether or not it came with an engineer's certificate.
The reply was:
No she doesn't have an engineers certificate. You just need to take her to
an NRMA and they will certify her for the modifications.
Ta
The car is currently in NSW, so I will have to have it inspected before putting it in my name - right?
..now I don't know how to take that. Does that mean that a certificate isn't required, but NRMA will provide something that I can show for the inspection? Or regardless of what NRMA can certify, anything modified will need an engineer's certificate?
Hmm.. pondering. Any assistance will be awesomeness.
Haha yea finally finished uni for the year neway.
I would buy if off you, if only someone would buy myne for 16 grand lol
Sucks your selling. Hilux aye? I so wanted to buy a reasonably new hilux and raise it with massive wheels.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
