The room fuse keeps blowing as soon as I put one in.
I installed a sub and amp into my car it was all good and working for about 2 hours then the the cd player turned off and theres no power to the amp or sub. I checked the fuses outside and the "room fuse" is out so i put another 10A one in and POP it wet out straight away.
Also when I lock my car with the alarm, after 5 seconds the alarm just goes off. Even if I silent lock it, the alarm still goes off after 5 seconds
Interior light also doesn't work.
Took out the whole wiring of the sub and amp and put it together twice, and it worked for a few hours then the same problem.
More info:
The amp is a 2x200watt audioline, the sub is 250watt, wiring kit is 8guage.
Need help ASAP, anyone do sub installs or know someone who does?
Edited by pablo101
https://www.sau.com.au/forums/topic/191646-room-fuse-keeps-blowing/
sound like theres to much load on system, another problem i have struck is the globe in the interior light gets faulty and makes fuse blow, try replacing the globe in the interior light and then replace fuse and see if it still does it
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
