  • Replies 367
Posted Images
i bet ur the wanker that did it. guys like u need to grow some balls
lol, sorry buddy, as i said, if it was me, it would have been bigger! much bigger! as for the grow balls comment, thats not nice... shut your mouth before i put my foot in it!!!
mate who do u think u are u have made a handful of posts and u come on here thinking burnouts are cool. ppl like u give the import seen a bad name. grow up u tool
White 33 GTR, actually. And no i dont give the import seen a bad name, people like you drivin around in nugget gtst are the problem thinking your mad hectic... soft
mate bring ur shit box boat anyway anytime and ur on. then we will see who has a nugget
Hmmm, i dont know what everybodys on about... i thought that burnout was pretty good!!! 10 points for tryin anyway
Its not the burnout, it was the place and time. I thought it was kinda stupid seeing as I saw the same patty wagon and Commodore wagon cop cars pass the place like 6 or so times sinse we got there. Not to mention the general public seeing a Skyline doing said burnout and associates that with every import under the sun.
I do admit, it was pretty good, but again, wrong place, wrong time.
Sorry Wing Wong - but for someone who is always at WSID keeping it off the streets, burnsie is far from what you describe.
:P
cheers,
Chris
Edit - Echo Matt - cassbo's comments. Wrong time, wrong place. Simple as that. Thats the type of tool we need off the roads.
mate, im ready and waiting! bring you and your blouse car round for an old fashion beat down!!!
mate im serious u beta be able to back that mouth of urs cos i will flaten u. pm me where and when and its on like donkey kong bitch
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
