On 19/11/2022 at 4:40 PM, Jack151 said:
Hi
I was looking at buying a 2004 Nissan skyline 350gt V35 Auto with 115,000km
Supposedly imported back in 2013 by a small import business there’s only been 1 owner
also would I have to get engine parts from Japan or can you use all parts from the 350z
Thanks
Ps This Forum rocks
Ive had my 05, GT350 premium for 15 years!. And have had little problem with it. My regular mechanic does the servicing. The common issues with these cars are:-
1. Door locks. Nissan ones don’t last so an aftermarket universal brand are much stronger.
2. The clock spring (behind steering wheel).Need to replace with a genuine replacement.
3. Airbag warning light- easily reset with ignition procedure. But you need to find out whats causing the problems.(Usually something to do with seat wiring or other electrical problem.
Cuong (Michael) at Revolution Electronics in Revesby, Sydney, knows these cars better than anyone. He done the door locks & clock spring, he even replaced the radio tuner the compliers put in with a better one when I first got it. He does everything in Minutes- its unbelievable how quick he is and he is very reasonable.
Other than these Ive had no other issues other than ones I cause myself such as not seeing/ removing the dirt off the tray under radiator which killed it!. I used Alexandria Radiators here in Syd as they made the only good replica at the time(fans too) for a very reasonable price. Genuine used to be 1600+ dont know now maybe cheaper..
good luck hope you get a decent one
cheers
elie
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7972904
  • 4 months later...
Hey everyone so i joined this forum looking for some help on my 2010 nissan skyline 250gt..so the the day i bought it after awhile of driving i noticed coolant leaking..with further inspection it was leaking around the thermostat area out of a small hole…i started to overheat and a check engine light came on trying to make it back home..after two days the leaking suddenly stopped(coolant was always full) but still over heating..i went to a mechanic and they found that my thermostat was stuck and cut the spring out so its always open(i live in a warm climate) after testing the vehicle it still overheat but this time the right intake is significantly louder that the left and radiator hose is rock hard to the touch while the reservoir is boiling over and the car is also misfiring..is that a sign the head gasket is bad or somethings else
Edited by Kesh20
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7978055
If it was “leaking from a small hole”..why didn’t your mechanic seal that ???.
You need to see another mechanic. One thing at a time. If you have leaks they need to be fixed. If the radiator hose/s are no good -replace it!. Then check your oil - if its milky/got water in it, you’ve probably got a blown head gasket.
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7978072
  • 10 months later...
Hi All,
Brought a 4 Door 2013 Skyline 370GT Type-S in November last year. Absolutely loving the car, noticed a few audio issues speakers cutting in and out and the 12V circuit seems to be completely dead (after checking and swapping the fuses) but just wanted to say Hi
Edited by OBwen
  • Like 1
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7987208
  • 1 month later...
Hi everyone,
Recently got handed down a 2004 Skyline 350GT Coupe. I would like to change the wheels as the previous owner installed some weird ones. The current ones are 215/45ZR18, unsure of the offset, and sit pretty deep in. Would like to increase the ground clearance slightly as well as I need to get it roadworthy standard, currently sitting at 90mm. Was thinking that maybe I could kill 2 birds with 1 stone by getting new wheels.
Pictures of current wheels: https://imgur.com/bg1QMIu
Any recommendations for the types of wheels I should be on the lookout for? Like the maximum and minimum offset, sidewall height, width, etc.
Sorry in advance if I'm noob, I do not know much about cars other than how to change the oil, a blown tyre and brakepads....
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989029
41 minutes ago, carnoobb said:
Hi everyone,
Hi and best of luck with your car. Its a bit hard to tell how low the car is all round from that pic or if its been lowered or not. 90mm is a bit low on the front apron but it depends on the shocks & springs condition & whether or not its been lowered. Going to 19” wheels will give you 15-20mm depending on rubber but you might need new shocks. Mine -2005 are weeping fluid slightly but have lasted 19years!!. So if yours are original they need replacing anyway if they havent been touched before.
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989030
Do you reckon 235/45/19 and 245/45/19 tyres would fit onto the 350GT? The wheels also have a +36 offset on all of them.
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989041
19 hours ago, carnoobb said:
Hi everyone,
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989042
Im sure they do because some shops asked to fit exactly that on mine, but I don’t know the clearances on your car or if its been lowered.
Your best best is to take it to a wheel & tyre shop (or try asking them) if you can get it registered as it is they will have all the answers. If you do go bigger just remember your speedo will become understated - this is why I won’t run different sizes to oem (that & I dont like to overload steering/ joints etc- even if it is very minor increase). You can change the adaptor on the speedo cable to the gearbox to get the speedo right too. Just depends on what you got planned for it. If you’re happy to leave it sitting down and just run around with bigger wheels assuming they fit / not bottom out- its not a problem at all.
  • Like 1
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989043
Do a search on facebook marketplace for V35 wheels. should be able to find some cheap ones to get it on the road
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989151
215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality.
245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989230
Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
https://www.sau.com.au/forums/topic/191705-newbies/page/51/#findComment-7989231
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
