Hey everyone whats up got a wideband problem and wanted to see if anyone on here could help me out. Car is a 95 gts-t mods are pod filter with cai, fmic, 3.5" turbo back exhaust with split dump no cat, boosted up to 12 psi, stock ecu and turbo with afc neo. Ok here is the prob got a PLX wideband O2 SENSOR installed the O2 sensor in the decat pipe wired it up correctly and everything got power and the instructions stated that no calibration is needed but if you let it get warm takes 45 sec and it is exposed just to normal air the display should read air did that and air appeared on the display. Now here is the dilemna ct the car on let it get warm reset my afc neo cause Im thinking all is good and I'll be able to tune the afr's myself so I let the car get to normal operating temp took a look at my display and it reads 19 now Im cruisn at 1500 rpm to try and get the afr's right for that rpm and the display says lean and the more gas I put in the the richer it gets but i set the afc neo to +50 and the lowest afr I got was 14.5 I think!!!! What the hell is goin on. I thought skylines with stock ecu ran rich why are my afr's so lean at cruise and I did it at idle and the same thing nothing below 14.5 WHEN I have added +50% on the afc neo and when I set it back to 0 it shows lean. Can any1 help?
https://www.sau.com.au/forums/topic/191844-wideband-o2-sensor-not-worth-a-fk/
Possibly try and recalibrate with the o2 sensor out of the exhaust.
On cruise your stock o2 sensor and ecu should have the mixtures fairly close to 14.5, even with a few mods. Have you got bigger injectors which may be a bit laggier than the stockers?
So you can't really tune at cruising cus what I was trying to do was tune the car to get the afr a bit lean at cruise, no I have stock injectors, still it doesn't explain why the wideband would read lean at idle and lean on the wide ban is anything over 20 there is no possible way for me to be that lean at idle with the stock ecu and no tune and like I state I had the afc neo to the max which is +50% and the afr's went to 14.5 at idle. Could the distance of the wideband O2 senor affect readings cus I have it right before the decat pipe.
sensor is too hot. i get a similar probem on mine when the sensor gets to hot. and there is no point trying to tune a safc on low revs/cuising or idle because the car goes into closed loop and "tunes" itself.
Is there any fix for the sensor getting to hot? Also how can it be if the max heat for the sensor is 850 C?
there are some very specific guidelines to follow and take note of when using a wideband 02 sensor
the main ones i can think of is
mount the sensor in the right position (location and the way it faces)
the sensor must always have power when running
be closest to the turbo outlet as possible
that being said ive had a wideband sensor up my exhaust muffle and it worked fine
be closest to the turbo outlet as possible(I thought it ad to be at least 24 inches away from the outlet for accurate readings at least thats what the instructions said)
After reading that I think I figured out the problem the a$$hole that welded the bung for my O2 sensor placed the O2 sensor in the bung and it was in there for a week or so with no power to it while the car ran its daily errands. So I think the O2 senor is destroyed, damnit and I just bout it, Man guess I gatta shell a couple more bucks out for another wideband O2 sensor.
double check but i remember reading that having the sensor in the exhaust and no power certainly can kill it
then wideband sensor i had in my car was hard run off the battery terminals so you couldnt cut the power to it
this also made sure the sensor was heated up correctly
So even at ignition off your sensor was still on even when you took the key out your sensor would still be on?
yes this is correct, as its a portable wideband sensor kit and not a permenant one it was setup to be temporarily setup like this on your car
so that it ran as soon as the earth terminal was connected. instead of being say on a cigarette lighter plug that could be bumped or unplugged they chose to direct hard wire it.
if you run the sensor in the exhaust stream and it looses power you risk frying the sensor, hence the hard wire method so it cant "loose" power
only took about 30 seconds to install
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
