I just need some advice, i just swapped a integra for a r33 gts-t and i want to have 300 rwkw on my car. i just wanted to know what do yous reckon the best and cheapest way to do it is and if there are some good web sites for me to have a look on to buy gear the the job ahead
Rossy
Edited by Rossy19
https://www.sau.com.au/forums/topic/191997-300-rwkw/
  • Replies 45
your new so just bear in mind theres a search function for next time.
and i wouldnt be chasing 300rwk right away as you jumped from an integra to an r33 gtst. do it up slowly and get used to the power. if your intentions are to use it as a street car then good luck getting traction :rofl:
good luck
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3452946
300kw is a masive amount of power.. I've had my R33 for 3 years now and I'm only pushin 265kw@ wheels and i still have a hard time drivin in the wet..
.. mate honestly, Get a full 3inch turbo back exhaust, FMIC, SAFC or E manage, boost controller and get her tuned to about 200rwKw.....
have fun.. :rofl:
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3452999
More like 15-20k but depends on how far you want to go. And as said there's no point wanting that sort of power but still wanting it to be cheap, because it just won't happen.
But its fun though :rofl:
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3453201
Hmm.. don't think you'll need 15-20k that much.
Injectors 740CC - $800 or so
FMIC - $600
Turbo GT3037 - $1,700 or so
Turbo Kit - $1,000
Fuel Pump - $250
AFM w/ plug - $330
power fc - $1,500
Twin Plate Clutch - $1,800
Coilovers - $1,800
Better Brake Pads - $250
Labour + Tune - $2,000
There you go :P. Should be less than 15k :rant:
However, how long your engine with stock internals will last with 300 rwkw, i do not know :down:
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3453355
Well there is at least one I know of with 300rwkw, but he knows he can't hold 5th for too long :( Still been going strong for over a year at least though! My engine all up cost me just under 7k btw, it was just a bastard waiting because let's just say it wasn't a planned build lol
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3453564
Stock internals would last with 300rwkw if you service it regularly and know how to take care of it with the best 'food' and supporting mods.
Some people blow their internals with 280rwkw some people run 310 rwkw everyday and engine is fine after a year. It all depends on many many various factors.
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3457268
FMIC - $600
Turbo Kit - $1,000
Fuel Pump - $250
AFM w/ plug - $330
power fc - $1,500
Coilovers - $1,800
There you go :rofl:. Should be less than 15k :)
However, how long your engine with stock internals will last with 300 rwkw, i do not know :P
+8k for the inevitable rebuild
+1500 for the diff
+1500 tyres (every 12-18months as you shred them)
+2000 - more brakes needed for 300rwkw than gts-t items
And thats just the start :)
Suddenly looking like a 25k adventure to me.
Basically if you cant afford the rebuild, you dont chase more than 250/260rwkw from the RB25
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3457285
Can u drive? Also is that wanted number just something to tell the boys about once u have it? or are you actually getting over driving cars with 200-250kws or whatever and u want to move on to something more exciting??
I'm not saying u have, but IF u have just come out of a front wheel drive Integra (no other cars) please start off with a moderately stock manual gts-t...
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3457895
I reckon it depends on how you drive it ^^
yeah 300rwkw sounds good but its pretty dangerous to drive on fr, esp on wet roads, even when launching straight you'll do a snakey
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3457927
200rwkw is pretty fast... let alone 300
remember - there's a difference between 300 actual RWkw's and holden's "300" kw cars
Edited by joeyjoejoejuniorshabadoo
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3458182
hahah, yeh like 30%. holden's HSV's would be pushing 200 at the wheels from the factory if that. 300rwkw is faaaaast, and not something i'd want to be thrown the keys to short of an intensive driver training course!
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3458202
FMIC - $600
Turbo Kit - $1,000
Fuel Pump - $250
AFM w/ plug - $330
power fc - $1,500
Coilovers - $1,800
There you go :P. Should be less than 15k :D
However, how long your engine with stock internals will last with 300 rwkw, i do not know :)
I disagree with the use of AFM and PFC , change of clutch and brake pads. Run MAP system with a better ECU, don't use pfc. Also stock clutch will be able to handle 300rwkw just fine, breaks will perform well enough again, let it worn before you change. Need a new fuel pump, boost gauge, intake temp sensor, full exhaust.
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3458578
hey mate,
dont know you from a bar of soap so not gonna judge you
but i think you're underestimating how much power 300rwkw actually is. Jump into a car with 250rwkw and you will be in for a shock. And when you think that thats quick - 300rwkw will blow you away. its alot of power for a street car, bit of overkill if you ask me - and will take alot of driver skill to keep it from decorating a tree/lightpole/another car.
go stage 1 mods and get 200rwkw first then work your way up. 300rwkw is a far cry from any integra - even type r's
good luck man dont go killing yourself just yet
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3458582
Nothing wrong with a PFC at all, it was just an example.
Not sure where you get your info from - a stock clutch will not handle 300rwkw.
Brakes wont perform that well (in my eyes)
Not a chance in the world.
https://www.sau.com.au/forums/topic/191997-300-rwkw/#findComment-3458622
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
