Upper Arm Camber Bushes
Uses the factory sensors? Which are currently the problem?
You can swap between OEM position or closer to chassis. Allows the suspension arms to be a bit more closer to OEM height geometry. My LCAs actually point down now, where as before they were flat. Overall real noticeable difference is I can put down close to 440kW on the street with no wheel spin. -
@silviaz Sounds like your making progress. Let me know how the door goes after you've got the primer down.
