33s only in the rear .. some 34s came with them, but we have one in the engine bay.
Looks really good man, pitty I could never even dream of doing that. what you get for buying a huge F.O sub.. Just a tip remove the back seat then remove the metal sheet bolted to the back of the boot, it lets sound travel better in the car and will remove the vibration of it.
Edited by DECIM8
yeah the metal sheet Decim8's talking about is in all 32s, 33s and 34s, it's held in by about 8x 10mm threaded bolts, makes a huge difference once you pull it out
I don't think it really serves a purpose other than being the rear firewall, which i guess helps stop flames if your fuel tank explodes for long enough for you to get out. not that it really matters though...once your cars on fire you are F**ked anyway
nice work. that should look mint... ill give some advice, if you want carpet, bunnings has heaps of different shades and really cheap like $10 a meter and its like 1.2 m wide!!!!!
Edited by Jimmyr33
Looks pretty sweet man.. just a stupid question, how do you get your spare wheel out? it dosent look like you can?
hahahahaha, good call. I love it when dude sacrifice a spare wheel for tunes. Commitment all the way!
funny you say that, i sacrifised a spare for my sounds, but i could have had both in thier, but i didnt due to my sub/amp combo being as heavy as my spare(pretty much the same weight), so i thought one wouldve had to go ha ha.Besides, i tried using my spare once, and trust me, it didnt seem safe at all.!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
