okay so i want a new car...
it has to...
around $15000 (might go higher if its a good deal)
be an automatic
look good
go moderately fast
not consume too much petrol
must have air bags and abs
must have power windows
not be too old (eg hopefully year 2000 +)
be not super expensive to service
easy to find parts for
....any ideas?
Edited by Lucy in the Sky
https://www.sau.com.au/forums/topic/192226-i-need-you/
  • Replies 54
The BA XR6 Turbo's are quite a good alrounder, a bit nose heavy to drive at times. You can get them pretty cheap too cos they flooded the market with them. 15-20K for fairly low kms. What size car are you after? Price? short range driving or longer stints?
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3455632
Haha, If it's uni student style, you can't go past the corolla, cheap reliable and cute! Mine lasted forever! and was mega cheap on fuel, servicing, parts, insurance.... did i mention cute?
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3455661
haha - i dunno about uni student..
i just find that twice a week i am filling up with at least 50 bucks and its kinda getting pricey..
i want something that still can go fast and stuff, but i just dont want to be throwing my money at petrol.
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3455668
1998-2000 Mitsubishi Galant VR-4
cost you about ~13k, twin turbo v6 with awd, and a 5spd tiptronic box.
looks good
14.4 stock 1/4 mile
~400km/tank
has air bags and abs
has power windows
they go up to 2002 models
mitsubishi can service them for a decent price
parts are common as anything in new zealand
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3455683
Hahaha, I'm really that my fuel goes on the company card. Unfortunately power normally eqauls fuel, and that can change a lot depending on how you drive it, from my experience. It used to cost $50 to fill the corolla (vortex 95) and I could get as much as 600km out of the tank depending on how i drove it.
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3455689
I'm pretty sure my mechanic now has a licence to import them....
You could always just get a bunky or motorcycle, my bike costs $15 to fill up and lasts the week :D Catching public transport is the pits, Ryan, y r u paying so much for the bus? an all day ticket costs $3 when ur a student.
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3455716
I think it's 4 zones from Atwell to Busport.. $4.20, but $3.15 with SmartRider (25% discount from cash) - plus im not a student
Aha, that's why it's so expensive. When i stopped being a student, it became cheaper for me to drive (bus and train took too long, and time is money).
Brad, Subaru's, though reliable, are relatively expensive to insure and maintain compared to generic aussie or jap cars.
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3455749
i was thinking.. as power = petrol consumption on a sliding scale together,
maybe if it wasnt powerful it would have to make up in the looks department... maybe along the lines of a cappucino, mx5 and the copen...
if i could afford it it would be a new mini but they are still 25 grand plus.
i think i would like a small car that looks good - not cute - i dont want a cute car like the jazz or a getz or a yarris etc etc...
https://www.sau.com.au/forums/topic/192226-i-need-you/#findComment-3456156
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
