hey guys n girls... my names Vish own a silver 4 door R33 gtst .. plates r 53XYN pretty stock cept pod full exhust system suspension n wheels, usually wave or flash my lights at other liners most times get a response back.
And you have Advan Tri-spokes and are always out at Griffith...
They picked me up 2 weeks ago for a fiberglass bonnet and unsecured airfilter, those things are fixed.
They went over it this morning and found:
1. Coil Overs.. Not ADR approved
2. Exhaust.. Not ADR Approved for Noise and Emissions
3. Front indicators(holden VY side repeaters).. Not ADR Approved
4. Parkers.. Blue tint?? WTF they are white, no sign of blue at all.
5. Headlights.. Dull and faded plastic.. along with every other 33 in the country
6. Rear Indicators and reverse lights tinted (i knew that one sort of just crossed my fingers and hoped they wouldnt care)
7. Steering Column rubs on headers (he was lucky to pick that up it only does it once in a blue moon) ah well...
Most of it is an easy fix, i still have the stock suspension and all the other bits ill pinch of the GTR for the inspection bar the exhaust thats gonna bbe tricky, though a good friend of mine is an approved exhaust fitter and testing dude.
Things they should have but didnt get me for, Large Holes cut in structural parts of the body, Wheels and Tyres scrub and are way to big, front tyres stick out past the guards, RSM and shiftlight on the dash no spare or jack, lots of Mod plate required suspension mods, but now its been inspected when i take it back they only check what they listed... oh well there bad.
Now that ive calmed down a bit its not a huge deal just a rather large expensive **** around, id rather be putting the money towards my non adr approved supercharger :D
spotted a tidy black 34 tailgating me on gympie road. Had personalised plates, silver lip and some kinda F&F kinda decals on the side....was trying to catch a good glimpse of it from rear view but had to concentrate on peak hour traffic as well...nice car if you're on here! :D
a good way t get that yellow fadedness of your headlights is to put brasso on them rub in, let start to dry then rub off well, brings them up bloody nice,
bad luck with the law man
tried to get me the other week, body kit not 100mm off the ground for one, while i was sitting in it, then when he got me out of the car and tried to show me but it wasnt under 100mm anymore hah
i rolled over like a timid dog and pis5ed on myself bein overly respectful and submissive body language (probationary point) and he didnt get me for anything, hah,
i thought he had me for speeding , and he did, but he let me off,,
roll over and pis5, but only as last resort on your probationary point
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
