Spotted and picked up Pete (R34GTX) at Chapman and Chapman in the morning. Saw Dangerous Daveo's car at Northfield Moorooka (and Drews R34 GTT and GTR). Spotted n15m0 at around 7pm in the city picking up people. I pulled him over with my looks :O
spotted a stegea with R34 front end .. looked bizzare.. near autobarn slacks creek ..
Should go in the stagea spotted thread :O
http://www.skylinesaustralia.com/forums/in...showtopic=53437
Was it silver? Looks great, but for ~$7000 I'll pass, still now the stock stagea design has grown on me :O
Spotted and picked up Pete (R34GTX) at Chapman and Chapman in the morning.  Saw Dangerous Daveo's car at Northfield Moorooka (and Drews R34 GTT and GTR).  Spotted n15m0 at around 7pm in the city picking up people.  I pulled him over with my looks :(
I saw the GTT, didnt see the GTR...
I was getting my new head deck in, its very very nice. Best $966.00 spent ever.
spotted a red 32 rego try32 .. while cruising down coast with my mates in their liners last nite... if the owners on here.. i wouldnt get in front of cars then chuck cig buts out the window ..frekin thing was wedged in my cooler core
Edited by 53XYN
hahah...you got it congrats? learn it all yet? is it the eclispe one you were talkin about? oh yeah, i went to talk to them about my boot and sound proofing....found out the boot is wrong...not really surprised...and a few things on the sound proofin etc.
Been seeing a silver stagea with the plates IOJ a lot around mt gravatt lately.
Heh yeah, I've waved before but I've been getting weird looks. Maybe they aren't really aware of what they are driving or don't like skylines
spotted a black GTR on the bruce Hway heading northbound just before the dohles rocks exit, also a very nice blue R32 with kit and front mount etc headin along the gateway motorway. orange R33 with dmd the image sticker on the side window and full kit and then on thelogan motorway 2 white R33's a series 1 and 2 following one another. was a busy day lol
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
