Silver four door 33 at Redbank plains, around 9pm tonight, doing fishtails in the wet in the carpark of the Redbank Tavern. And also losing it whilst turning a corner in front of the tavern
You are a dickhead
choy turning onto kitchener street off french street in coorparoo tonight at around 7.30.
hot blonde chick (probably 19 or 20yrs old) driving a r33 gtr (purplish) heading into the city around 8.30 tonight.
r32 blue turning into springwood macca's at around 8ish.
a fair few skylines out tonight. good to see!
Was up in Mooloolaba/Maroochydore last night.
Spotted a white 33 near the outrigger
Maroon 32 with black bonnet near the skate bowl
White 33 with black bonnet and GT wing, who was being followed by a R33 4-door, just outside Sunshine Plaza turning onto Maroochydore road.
maroon 32 parked on Alex Hill.
R334Door, yeah, was last night (saturday night)
i was standing on the side of the road out the front of the pig and whistle as you guys were turning up maroochydore road.
also spotted just before:
White R34 heading along anzac avenue into redcliffe.
also saw a Silver R33 S2 at the lights outside North Lakes at 5:22 (i looked at the clock, lol), you were heading up towards mango hill/redcliffe. You had an SAU on the drivers side 1/4 window.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
