saw n15m0 jus outside sunnybank plaza entrance this afternoon. Car looks even better in person :)
Thanks bud! :P
Spotted 2 34s driving along park road today...a white 34 coupe with personalised plates and also a black coupe with nice wheels...sometime around noon.
Spotted girl in R33 white with a playboy sticker on the back and a stuffed Playboy head hanging near the exhaust. Can't say I would do it but her ride looked tidy... :P
Spotted the same GTST a couple times turning into Fredrick St in Boronia Heights.
Nice play bunny stuff haha, gets a thumbs up from me.
I spotted "R34" The neon green R34 with the plates "R34" @ cannon hill just round the corner from work...
I also spotted a Astin Martin DB9 Vanquich (spelling) on the Bruce HWY heading south from Burpengary exit. He went through the speed camera at least at 130kph... Fool...
I bet it was parked on the side of the road, and you just thought it was going 130kmh, they just look fast!
of course you'd thumbs it up
play bunny merchandise is only a stones throw from having decals on your car that say
"I'M A DIRTY WHORE"
haha thats a funny but true comment !.. im still buzzed with this chick who drives a white 33 turbo plates PRI71 .. daym her ride and herself was fyne !... :)
Spotted a Clean nice 34 White 4 door on mt gravatt capalaba road couldnt get the plates :)
When I saw it man, there was some bloke in the car. So I think your right out of luck!
people who own these cars, dont care about speeding tickets
after picking my car up from Xtreme motorsports.. i saw this hot yellow 34 looked fulli sick wit this good looking chap .. suddenly i realised it was me !.. damit !
Spotted Nur34 on moss street white 34 gtr alex waved back :P
P.S someone needed a bit of humour !
Edited by 53XYN
"I'M A DIRTY WHORE"
Totally agree, but as I said not my thing......
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
