spotted naw71 skyline driving through a house in brisbane on channel 10 news
nice driving!
perhaps being double the limit mite have had something to do with it
Yes the number plate says it all.
saw 53XYN in stones corner...
u waved and i waved back but my window was up... dont know if u saw me wave back though
Saw u way before you where turning :no: its all with the RB sound ... your car looks smick !
i saw 3 r32 as i was exiting into the bp at dreamworld, side by side was very sexy had to go spend some time in toilet he he he (coming home from mountain run)
although you boys were driving awefully slow he he he
Spotted a White R34 near Habour town down the coast yesterday afternoon, around 5 I think. Dropping the sister home... damn uni on the coast! :huh:
A black R32 parked at the yatala bp last night. Don't think he was a SAU type person though :(
I think I saw Destro ala Ben along browns plains road sometime last night... around marsden, you boosted through a yellow light, naughty naughty, though the car next to you was doing the same (lacking boost) hehe.
Spotted a silver 33 GTS-T with graphics down the side and a SAU sticker at the intersection of Old Clevelend Road and Logan Road (near the NAB and Suncorp banks) on Saturday morning.
Never seen you before, nice ride. Hope to meet you at a Tuesday night dinner sometime.
thanks dude...
just a bit dirty right now drivin around doin all the photos.
yellow turned out nice under that light when ur turnin :(
thanks man .. its not a bad color to keep clean either .. wouldnt mind a group shot of all yellow skylines :huh:.. mine has a green tinge to it .. i dont know if others are like that or not..
un fortantly im late paying for SAU membership might try the next yr photo shoot :huh:
Spotted brr87 (Silver R34) at amart on saturday. Is that you Bryn?
That was me :) i thought u would of remember me :)
SPOTTED YOur car on the driveway this evening aruond 7ish, i like the rims.
That was me :) i thought u would of remember me :verymad:
I can't remember my own plates let alone somebody else's :)
It's on the street atm now :verymad: Because stupid me flattened the battery in the 31 while working on it today and now it has to charge
hmm i might go walk my dog, and have a closer look at it :)
Also, does your MUm remember following me hom that time (probably to abuse me for how i was driving) i noticed she was tailing me, so i didnt stop in my street, drove to the complete over end (your mum still following me) and then back onto main road and hammered it outa there :verymad:,
Oh happy days
hmm i might go walk my dog, and have a closer look at it :O
Also, does your MUm remember following me hom that time (probably to abuse me for how i was driving) i noticed she was tailing me, so i didnt stop in my street, drove to the complete over end (your mum still following me) and then back onto main road and hammered it outa there :O,
Oh happy days
Never mentioned it?
yeh i was out and about around that area last night. u wernt in ur skyline when u seen me were u?
yellow light = speed up :O
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
