Spotted a Silver s2 in the switch today.. came out of side street near Nth ippy caltex, VERY sideways i might add.. looked gud from where i was sitting but give us liners a bad name... coz we all know that none of us do that :wave:
Edited by Mitty
Next time you see it take note if there are twin cannons sticking out the back. He does a lot of that sideways stuff. Saw him put it up on the traffic island one morning. Damn quick car too.
spoteed some dude in a red 33 on the gateway bridge this morning, sat beside me for the whole length of the bridge.
if you saw my plates and have logged on to have a look, hello !
Did you abuse him too?!?!?!?! :stupid:
Spotted a white 34 Tues morn at Paddington outside that old burnt down skating place :happy:
Spotted Ad_N at the corner of Beaudesrt Road and Ipswich road this morning...I waved you looked confused, then I was like WTF sif not remember me I was talking to you last night..then remembered I didnt bring my car to dinner lol
Spootted a silver 32? on Evans rd salisbury (I think he works there) seen the sau sticker and honked and waved like a crazy lady........
sorry if I freaked you out! :(
hey at least you got the spirit alot of the people dont wave cause they dont want to look like fools....personally i like to swerve at them cause they see you then.
Thanks I felt like the biggest knob! was that you??
lol nah i would have been hangin out the window waving back :ninja:
i do drive a silver r32 though. plates 57IGG.
If I see you round I'll make sure I hang out the window and make an even bigger knob of myself!! Just please dont swerve at me, I'll probably hit a pole or something!! :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
