i spotted on the highway today between morayfield and sunny coast. a r34 GTR in that paint that changes colour (green, purple blue) im in love lol
skyline imports hack job.
It's a GTT with GTR guards + all the other stuff.
spotted 666DAN on gympie rd tonight near kedron...
also say a wide-wide-wide bodied R33 GTST, metalic blue, with some super super deep dish rims at sunnybank plaza tonight. the car has a team jetspeed sticker on it.....almost looked like a VIP car.
Haha I said to the gf I bet I get spotted while venturing northside :(
Had a shit day spotted a few people though
A dark silver r32 on anna st in the valley this arvo...got a wave back...champion.
spotted 51PRY twice.......
And drove next to a s1 r33 on the motorway tonight...got a wave too good man.
cheers
