Bit slow with my post but spotted a clean looking Black R32 on Bradman Street at Acacia Ridge, near Beaudesert road/Llerroyd road. I think it may have been RBR32?? I was on my way home from work so it woudl have been around 4-5 maybe??
Spotted a black R32 on Logan Rd (near Freedom servo) this morning. Can't remember plates (maybe [***NUG]?), but had the stock wing.
Anyone on here?
are you sure it wasnt you in the reflection of the shop window. Was it keeping up with you?
spotted white 34 4door 73ENA @ Marinellis Performance shop this afternoon
My guess is it belongs to Teena :laughing-smiley-014:
oh, bout time you washed it, it looks better clean.
Hehe, yeah that was me!! The 34 was getting her service done ready for the cruise this weekend. Marinelli's seem really good! I'll make sure it's nice and clean for this weekend at least!
Teena is your U13... a attessa 4wd SR20 turbo one? way off topic but curious cause not many around
Nah, unfortunately its the aussie KA24DE FWD bluey SSS. Still an awesome car though, with heaps of features. I wish my 34 had the cruise control and HUD.
Saw a black R32 on the road in sunnybank that runs along the train line off of orange grove road near Boundary road. I think they were waving, but I appeared rude and didnt really wave back because I was being blinded by the sun and only saw them at the last minute!
Didnt know if it was anyone off of here. So Hi if it was :laugh:
Spotted - Tidy White R32 along Orsova Terrace...Seems to work at Caloundra Council :(
Saw a maroon S1 R33 heading toward Caloundra on Caloundra Rd... got a wave back
^^^^ that was me .. with black mags yes? :laugh:
Edited by Logikal
Didnt know if it was anyone off of here. So Hi if it was :sleep:
hey mate that was me both times :D clean looking? ha! i must have washed it for once before hand.. i think i waved or nodded in approval :D past 2 days i have had my drift tyres on my front as my road tyres were showing steel radials (gulp) anyway i got my new tyres today yay... although, i spent my drift money for june 1st @ qld raceway :P
saw a nice 2 door grey 34 on st pauls TCE today near bowen hills too, didnt catch the plates, about 4:50 pm
and a nice champagne (gold) 33 on corro/inner city bypass tonight also. bout 6pm
Edited by Benno-
Spotted MRO33 this morning about 8.30am on the ippy motorway.
Whoever the knob was in the team spaz (stickers plastered on every window) white 33 driving next to you, just about wrote me off as you were exiting, just before i waved, as he tried to merge straight into the side of me. You might've seen it all in your rear vision mirror. Note to that driver, check your blind spot before you change lanes, as i had to hit the skids and swerve around you, as you still kept coming over even once you saw i was there. That's just rude.
Edited by Miss Niz
Didnt know if it was anyone off of here. So Hi if it was :)
Could have been me, I go past there at bout 4:40-5, seen a 32? yesterday with a white panel or something on the front right???? I fully waved like a nutta??
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
