Spotted a white R31 with black bonnet and stock white R33 at Hungary Jacks Browns Plains, friday night. Spotted GTR, DUBAI on pinelands rd on Sunday, a yellow 32 on middle rd (hot car by the way) and white R33 WKD33 on Sunday arv. DUBAI is the sweetest line I have ever seen......
spotted a red r33 with black rims, near northfield nundah pulling onto sandgate road, had sau stickers....
then spotted a black r34 with i think the tomy front bumper?? pulling onto sandgate road near the shopping centre, ive seen you around redcliffe :P
then on way home from city around 9ish was driving with a 31 white sedan from airport all the way till deagen diviaton
Edited by Silver_R34_GT-T
lol. do u go ther..? who owns that ridicuously huge wide bodied R33.. barely fits in the skinny park spots ther.. :whistling:
yeah i'm there for the next couple of weeks. not in my car though, doing work to it so its undrivable.
havent seen the r33 yet, i'll keep an eye out.
also spotted a yellow 34 at the intersection of creek and old cleveland rd this morning, 7.45amish plates were OOR-34
saw a r34 gt-r vspec midnight purple traveling down logan road
trade plates hmn wonder whos this is :google::P
Spotted the same one in Mt Gravatt
Hot ride
Edited by Along for the ride
Spotted a black 180sx i think his name is MARKIMAK in these forums at the drift practice @ Archerfield this afternoon.
Carl
hey carl.
yeah brother. was a pleasure meeting.. u did some pretty thick smoking skids in the R31 :D
perhaps in a few months with more practice we could do tandems :P
ill catch ya at the next one.
i would say it was you as there arnt many skylines painted in that colour.
did u get urs from the import yard on ferry road?
theres actually a 2door 33 that sits in a resaurant car park across the road from jupiters thats the same colour as mine
wen i saw it i was shocked. its a stock grey/blue colour off a nissan bluebird too
and yea i got it from MJR on ferry road, y u ask??
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
