spotted Glen PNK32 on Edward Street opp the Victory last nite by the time i got towards you were gone.. was n foot , also spotted 911-GTR R32 on the M! a few moments ago was in the lancer
Spotted SPOILD R34 Coupe near gardencity today 11am
xxx-IOJ, white R33 GTS25t with what looks to be a boot lid from a GTR V-Spec (spoiler, badge and sticker), V-Spec front bar etc, a bit of other damage so suspect it's been fixed with parts from a wrecked GTR. Bad luck mate :\
Spotted white R34 with black tribals on the back...gave me thumbs up...I asked if he was in SAU....said 'nah' then I watched the show as a 911 porsche pulled up next to him...couldnt keep up though...(non-turbo 4 door 34) :whistling:
Oh....also spotted silver 4 door 34 with only front kit at 'WOW' underwood...2nd time i seen ya....
spotted a black 32, red 32, black 33 and white 34 cruising noosa parklands on the weekend. The black 32 sounded very angry blasting up 'the hill', actually they all sounded very nice. Good to see the north sunny coast boys enjoying their cars, keep it up.
R32 GT-R from Lydon Rd turning onto redland bay rd towards Vic Pt
Also at same intersection same time, R33 GTS-T with some sorta kit on it going towards capalaba, would have seen the 32 aswell.
R32 GT-R at about 9:20pm in cleveland
So many skylines around, i'm so lazy to post.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
