this is cool. Well I'm Bryan 18 year old - and i may look like every other asian in Brisbane Sunnybank. except I'm from SINGAPORE. And I'm NOT a rich daddy's boy who got a "free" skyline. Mine is the one which has cheapo mods to it because I'm currently poor and jobless. Got my car vandalise yesterday btw, so if u see a maroon car going around with body filler everyone - ITS ME!.
  • Like 1
On the ever so thrilling drive to work down the gateway this morning (at about 5kph for an hour) there was a Black 33, very nice machine. I was right behind it and then went down sandgate road, and came backonto the highway at the airport a whole 2 cars in front of it. Got to love that road.
Also saw what I think was a medium blue 32 on the southside about 9ish wednesday night, around the mt gravatt area.
I think I am yet to see anothee line I know out and about (with the exception of track days).
Hi. I'm Erin. I swear there is already a thread like this somewhere.
I drive a white R33 with mags and personalised plates :P
I normaly smile and wave to anyone with a skyline but they normally don't wave back..
Maybe that's because I'm ugly or something :|
haha .. i doubt that's the case Erin ... maybe they are just expecting a guy instead of a gal in the driver seat :-) ... by the time they gotten over it and wanted to wave back, you are long gone...
GenesisR32
My names Michael or will usually answer hey you, that guy or Knoxy, Drive my wanna be skyline U12 Pintara, slowly puttin bits and pieces on it, put in extractors then exaust back from there and thats as far as i've gone due to maccas pay sucking.
Work at chermside and live in brighton, startin my appreniceship as a mechanic next year
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
