was commen home from camping and saw a red r34 leaven a house in kenilworth, we also turned around in your driveway :thumbsup: had some sticker in middle of rear windscreen with gold rims
walking on newham road spotted a nice caribian blue v35 s1 coupe , and a blonde chick in a red gtst with GTR kit badge etc.. front bar in primer speeding on newham road and locking up her brakes what a idiot ....must been a bogan plated were 309.Kxx...
Spotted a gun metal R35 GTR heading south on the Gateway around 5.30 today... Sounded sweet.
And 20 minutes later a tidy red 34 4 door - lowered with chrome rims and nismo kit on Buckland road Nundah.
.. sorry didn't catch the plates on either.
spotted 71BBY yellow R34 @ D& R Stainless .. and a yellow R33 GTR with rear damage on opp side of the progress road .. seemed like it was hit pretty hard
Also spotted a blue R32 @ Ludiwici had plates something like RRB20 ??
spotted a maroon n\a 33 going past vibes at moobah and few other turbo lines... then about 9 30pm ish i went into and out of 7\11 maroochydore few 32's and 33's in there (you didnt seem that friendly) LOL
drove down to goldie from sunshine coast monday arvo and came back midday today and saw no skylines except one exiting just past the twin BP's but didnt get a good look as there were trucks everywhere.......disappointing
Saw R33 GTS-T this morning at about 7:30 am on redland bay rd... driving behind some car, saw an old rx7 maybe? didnt see it...
got crazy, 2nd gear, BOOOOOOOOSSST, rear wheels spin squeel and off it goes. PUFF.... smoke haha
Not bad.
spotted a white wingless 34 female driver and a white 33 behind it passing pac fair at around 1:30pm today
and a silver 33 turning right next to the caltex just before the M1 starts on Smith st
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
