spotted 50.FLI immaculate R32 GTR in that rare dark blue colour with bronze TE37's :P
so fli is one of the sexiest 32 gtrs in brisbane IMO, i used to work near him/her and see if almost everyday :)
member on here?
To the wanker in the black s15 with fail offset at georgios drive threw in wynumm yelling out skyline fag and other obsenities whilst behind me. I had my wife ad kids in the car you tool. Your lucky i didnt get out of the car and spray yours with a bottle of coke....mort!
End rant!!
End rant!!
NS Bogan, or Boostloosing tool :shakes head:
Spotted my car in the garage for past 5 days waiting on new radiator. :laugh: which arrived today :action-smiley-069:
End rant!!
We got a heap of Sylvia's in my area and all of them are hooning knobs except for my boss =P
Spotted a yellow 33 with a 400r kit on. Normally not a fan but this thing looked excellent. Also spotted a silver 35,noice. Both on the sunshine coast hw near the mooloolabah/buderim turnoff.
Cant wait to get my car, 3 days to go.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
