Spotted a black R33 lotttttssss of power :) - 912LHU were the plates around 630ish tonight on Anzac Ave Kallangur.
Spotted him last Saturday too around 3pm on Linkfield Rd, Brendale
anyone know who he is?? is he on this site?
There is 1 that fits that description that lives down here on the Goldy, saw it again yesterday on my postie round-tuned by Gavin Wood too-sounds extremely hard core
black 33 coupe with no rear wing?
he's around here if its the car im thinking
yeah no rear wing on it, couldn't even tell you what rims it has, was too gobsmacked with the sound of it haha
White R34 ORG33 on the M1 around 2:30am this morning followed me off the Helensvale North exit. Nice clean car! Did you upgrade that recently? I remember those plates on a white 33. Was a fast black Ford playing with us too :-)
Edited by Midnight Madness
White 4 door 31 Redwood Street Stafford ***MYK
White 33 Redwood St Stafford 347*ALL
Blue 33 Redwood St Stafford couldn't see plates
Purple 4 door 32 Rutherford St Stafford ***JBM
White 32 Maundrell Tce Chermside West 352*LTR
...seemed to be the night for Skylines on my drive home :down:
I see that Blue 33 alot in stafford actually. I also see a red R32 a few times and everytimes im hoping its you and get ready to waive but no its not =[.... We are destined to never run into each other lol
I'm not sure if the blue one I saw even runs. It's been in the same spot in their driveway for months now. It's sort of a superman blue, that the one you see?
There are two other red 32s around here. One with no spoiler that gets around the Aspley area. And one really hot one dropped low on USA Meshies with side skirts to complete their body kit (bastards) that seems to get around Kedron/Stafford. I always look to see if the white 33s are LEBs lol, but nothing yet.
White 32 with gay body kit and gay crystal tail lights on Beatty Rd at Archerfield.
Red 33 on Balham Rd at Archerfield
Oh... and not that I really consider it a Skyline... but I saw a gunmetal R35 on Lutwyche Rd today about 11am heading inbound. Couldn't read the plates but they were standard issue QLD ones. Wash your damn car by the way, it's filthy.
that was me. car has been sitting at a workshop for a few weeks. I was returning it to another workshop for more work.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
