Dark Purple 32 4 door 816-JMB Friday afternoon on Albany Creek road. Car has a www.skylinesaustralia.com sticker on the rear window. My GF saw it and took a photo to show me (She's well trained).
She loves the color of your car, but was disappointed to learn I didn't know who you were.
I think I freaked out BECKS.
haven't seen it since I said I saw it.. lol
To clarify - I park in the same parking station - that is why I see it all the time.
or you drive past as I'm walking to my car after work..
I don't hide in the car park looking at your car. lol
HAHAHAHA Takes a bit to freak me out.. Especially in the Valley lol
What car park? China Town one?
I've moved back to good old McWhirters .. (With 2 exits lol)
Silver R34 GT - Nismo badge on back - Orion
Silver R34 GT - slammed no spoiler, driftek - Redbank Plains/Brookwater
Silver R34 GT - FAB87 with pink flowers hanging off rear view mirror - Redbank Plains/Brookwater
All within 5min of each other.....
I'm thinking this might be my old car which I drove up from Sydney some 4 years ago..
back look like this?
when I had it it looked like this..
Plates I had were REL15H
sold it unregistered so it would have got QLD plates.
some months later, I saw it on some horrid chrome wheels.
such a shame.
Edited by GTST
seen a few over the weekend..seen a gray 34 at the stafford rd/appleby rd intersection on friday ding skids from the lights.. Stupid behavior specially in peak traffic....
Saw a black R33 on Newmarked rd as i drove into work this morning
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
