followed a maroon 33 with the plates EER33 from cooroy onto the highway to the bottom of black mountain. i have the following observations to make. 1: one of your tail lights is faded so it is more yellow than red. 2: your car is running pretty rich. i could smell it inside my car with the windows up.
now for comments on your driving.
you weren't able to stay within the lines. for the few kms that i followed you, you were constantly varying you speed between 5 to 15km/h under the limit. then when we go to the overtaking lanes and i tried to pass you, you sped up to 20km/h over the limit so i couldn't get past without flooring it, and then you slowed back down once i was past. you're a deadset dumbass. you may have thought i was wanting to race you because i was constanly getting closer and further away, but that was just because of your poor ability to hold a steady speed meaning that i had to keep slowing down and speeding up.
Try T-Mac, Power Street?
ah yes, that's right. think he may have worked at ford before T-mac, but i could be wrong.
this morning i spotted a white r34 (possibly GTR) with gold wheels heading north on the highway in gympie at the top of the golf course. i was the fella on the bike (in lycra) heading back into town.
and on wednesday i spotted a silver r32 4 door that belongs in the "what not to do to a skyline" thread. it was on steve irwin way heading towards landsborough. had some mildly ugly front bar, eyelids that covered half the headlights and had a strip of LED driving lights under each headlight.
I see loads of young skyliners out southside way and always give the captains wave!! Say Hi back!
34 midnight blue sedan 611MAB is the daily with gun metal rota boosts or on weekends the 34GTT white coupe with GTR wing and BBS wheels.
Must put a SAU sticker on one day!
yeah that's the one. used to live on rifle range road across the road from my grandparents place. i think the guy who owns it works at ford/nissan/mitsubishi.
yeh i used to spot that every morning too on the way to work
Think i followed blackers for a few minutes heading towards 7eleven on the morayfield road, hell no i wasn't waiting 3 times for those lights before i could go. they are a pain in the ass
I moved to Toowong last Tuesday and haven't seen any Skylines around the city at all. Then I went to Sunnybank today and saw heaps. Best two - a very clean looking silver R33 GTST coupe at Sunnybank Shopping center and an R34 GTT sedan with a chunky URAS bodykit - MRR34.
Edited by R34mac
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
