ok home. been cruising all weekend. I think I waved to every skyline out there.
As you can see I wasnt driving :devil:
yeah front bar was from friend that didnt know how to drive a lowered car. he no longer is in brisbane. Anyway was hitting the streets everywhere all weekend, north south east and west(also very west). But yeah I'll have to get to meet people so I know who drives what.
(btw) Im the guy in the passenger seat.
Saw a white 33GTR in the wesley hospital carpark on friday night, had a 400r front bar, had IMS sticker on the side and some other motorsport sticker n back window, spotted a DVD player inside, and some nice M3 style mirrors.
I was the guy in the red shirt drooling over your car but too shy to say hi. Does anybody on here own this car.
Anyone here own a Maroon R33 and was drifting, really badly, around the roundabout for 20 mins on the corner of Cheltnam Dr/ Thorngate drive in Robina on Sunday night.
Great work in a suburban neighbourhood at 1.00am champ.
No wonder the police are on everybody's back.
Save it for the skidpan or industrial areas dickhead!
F*CKi^G WANKER !!!!!
