Dark grey or black 32 near Hope Island - if you are on here you dump black clouds of smoke like a diesel car
Spotted 2 more skylines along the motorway heading into the city.
Lol sounds classy.
spotted 2 r33's in the last few days cruising around Moronfield. Waved, some degree of response aquired
Lol sounds classy.
Too confused as to which hand to wave with most likely. Either losing street cred by lifting arm off door, or losing control by using steering arm!!!
I know this is an old post.
It is one of the better one I have seen.
So many times I have drivin past people in skylines and just givin them a wave. Birds of a feather flock together and all that.
I drive an R33 GTS-T Coupe.
It's silver in color with like a Death Horned worrier Air Brushed on the bonnet and Skulls all over it
Names Pat. Have a yarn.
I wouldn't mind gettin to know a few of the skyline owners on Brissys NORTH SIDE.
Exchange ideas and thoughts.
Can't miss me. My car sticks out like a sore thumb.
GOOD POST.
KEEP IT ALIVE.
Hi Pat *waves*
I'm also on the Northside. If I see you getting around I'll say hi.
My car also sticks out like a sore thumb so if you see a silver R34 with a feral looking ding on the passenger side, feel free to say Hi.
I drive past a yellow 34 pretty much everyday. It's always parked at Stafford State School (even on weekends) so I'm assuming they live in those townhouses on Webster Rd with no driveways.
Another Skyline R32 pulled over on Gowan Road tonight, cops making a routine of patrolling around here every night!
Is there one particular spot on Gowan road that they wait or just random?
Edited by Missileman
95% of the times I've seen them between the Compton Rd. intersection and the southern end of Gowan Rd. There's a cop station on Kameruka Street, probably the source of this activity lol. Always skylines, somehow I've slipped past every time :S
I mainly use the Compton to beenligh rd section, might be time to hide boost controller anyway, my exhaust should be very close to legal though.
There is that down hill section just after the Nemies Rd. T junction (going towards Beenleigh rd.), they love to camp there with their speed guns :P
Edited by fusion07
Just landed finally and complied my 33 gtr in midnight purple, very very happy camper!! Not sure how to put pics up from my phone but will get around to it.
Don't post up pics, come to a meet! Bring her out and show her off! Well done mate - hope that she's worth the wait. :)
Also, pics. :P
Didn't get up it too much as wana tune it first and get compression check etc but very impressed with the small press I gave it !
Wana catch up with all in the club but with work I'm away a lot and can never line up a day with ya's ! One day
Cheers
Cheers
Pm me and I'll see if I can work my magic.
From South Australia and driving around in a BA XR8, then bought a GTR in NSW.
To be honest I was in NSW and hating it, No car culture no nice cars on the road ( least not as often as SA). I thought " ah shit the p plate laws have ruined it" ( no p plate laws in SA until recently)
Drove from Sydney to Ipswich and to be honest had a shit time of it , rear tyres started falling apart due to age ( car sat in a shed for years) got a country bloke to come in on his day off to fit 4 el cheapo tyres for an not so el cheapo price.
SO had a shit drive when I'd been in QLD literally 10 mins when a 35 GTR and a 34 GTR appeared, I Loved it.
an hour later worked to the teeth STI, then another 34 GTR.
Made my week.........
look forward to seeing a few nice cars in the Ipswich area
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
