saw a grey 32 gtr on the riverside expressway this arvo, cool green 33 in the myer center car park this arvo and a silver 33 in the city cant remember what street it was, near qut though.
Just whipped down the road and handed one of Adrian's you beaut windscreen flyers out to that white R33 who's owner works just around the corner from me, had a great chat so we might have another joining our ranks :)
black 33 at indooroopilly this morning at about 10:30
driver was speeding in the carpark....tsk tsk
What is it with that?
Shopping centre carparks are the domain of women and small children :slap: both of which can be VERY unpredictable (no offence Erin :))
cheers for the gentleman and his partner who spooled up next to me at newmarket tonight havin a bit of fun (no racing though) giving both us and him a good chuckle. Nice white 33 with 17"s and Advance auto imports plates. When I get older, I'm gonna phcuk with young'uns in souped up cars. Good to see that boys never really grow up.
and a cheer for the late model commodore driver in his fifties with wife who also had a rev or two to say. :)
I'll be the first to admit that females can't drive :) I've always said that.
I saw a white R33 on friday next to Toowong Shopping Village with the plates 247 GQX .. I think. I was about 20 metres away trying to read them.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
