There was a green liner written off last night in peak hour traffic on moggil rd in Kenmore. Was bright green 33, was driving past at the time so didnt get a great look...
What time did you see this steve?
We saw the GTR wannabe one at 4:30 yesterday arvo wonder if it was the same one.
Is prolly the same green 'line. The one I have seen parked at Milton I have also seen out Kenmore way more than once.
I previously said 'R badges' because it didnt look quite right to me, but I wasn't sure and didn't want to go getting the owners nose out of joint...
Hello me name is alex just got a silver R34 GTT recently, still getting used to the car :)  I drive around Gold Coast abit and sometime in Brisbane City.. so give me a wave if you see me.. if you want :D
Have a 'little' wing at the back of me car.. so some people might have already seen me around abit.
Hey NIZR34GTT are you the guy with the red 4 door GTT with the nismo dash? :(
And DAN666 saw your car at the broady a week ago as well? was going to come and say hello but didnt no you or where you where. *shrug* :)
Two door with carbon forbre dash,lol close to both of them.
basically what you do is sand it back till you get it clear then stick a neon behind it and put a box around the neon to conseal it. then just wire it all up etc wouldnt be too hard at all. The guy who asked wanted it to glow red as the green came factory standard on some skylines.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
